Gaz. wrote:The drivers have said before that you can pre-select a downshift but it won't happen until the engine is below a certain point in the rev range.
I've seen fluffed downshifts lock up rear wheels in modified RV8 TVR's running high compression ratios but that was a result of too low revs locking the wheels of a car with no downforce on road tyres at low speed - it's pretty much the exact opposite situation. I've also heard of someone buzzing the engine of a 996TT by downshifting to 3rd instead of 5th but instead of the tyres locking, the camchain snapped and the engine turned itself into scrap.
iirc Vettel had a similar spin in Bahrain winter testing.
Thanks. That's exactly what my assumption had been to. You actually don't have to go very far to see fluffed downshifts and locked rear wheels... A couple of years back, I nearly crashed a Lotus by downshifting agressively ahead of a corner and let the clutch slip which caused an instant lockup of the rears. I was still naive to any concept of heel & toe shifting back then. Also, a fellow mate who owned the same car experienced an engine failure by selecting 1st gear instead of 3rd on the race track and buzzed te engine. Go figure... (and don't asked how hard he must have forced the gear into position to actually get it in there). Anyway, that's all with a mechanical driver controlled clutch and gearbox.
Shifting with paddleshift where the clutch is controlled electronically, automatically matches revs on downshifts and failsaves when revs are too low or high, this shouldn't happen.
I do have an idea how the lock up might have occured though:
Various reports suggest that the Austrian track was quite bumpy. Following the season so far and how the Mercedes (as others, I'm sure) agressively harvest energy on the rears, they might still be running quite a rear-ward (relatively speaking) brake-bias - or pretty close to the limit where under more extreme braking conditions, the fronts may lock up just ahead of the rears.
During qualifying, the car is at its lightest with arguably the highest engine setting, so you will also have the highest stopping power during that session (compared to the race). Imagine coming over a bump at these speeds, while under braking when the entire weight of the car shifts to the front and there's less friction on the rears. Running a (relatively speaking again) rear-ward brake-bias and this could be enough to lock the rears ahead of the fronts enough to cause a loss of control. Especially if you're on corner entry at the same time and the lock-ups of the rears will cause the whole car to spin (if the fronts were locked too, the car would just slide forward)
If this is the case, I don't think the driver is much at fault - just an unfortunate chain of events magnified by a bump and the strong harvesting of energy on the rears (that results in quite a bit of braking force at the rears). Also, would not be really reproducable during the race, since the cars are running quite a lot heavier, so less chance of locking the rears than when using a significantly lighter and quicker car as is the case in qualifying.
Just my 2 cents.
