Caterham CT-05 Renault
Re: Caterham CT-04 Renault
how can an engine not fit in a chassis?
They must have tried to fit it with the turbo on. At Redbull they fitted the engine first then the turbo and anciliaries.
β˜„οΈ Myth of the five suns. β˜„οΈ
β˜€οΈβ˜€οΈβ˜€οΈβ˜€οΈβ˜€οΈ
LxVxFxHxN
beelsebob
beelsebob
85
wesley123 wrote:how can an engine not fit in a chassis?
Presumably because the mounting points are not where they were meant to be... But the car was meant to have been fired up days ago, what's going on here?
For anyone who can answer. Why is the car called CT-05??? was there a CT-04 that was scrapped or what? Or did Marrusia purchase the Ct-04?
LxVxFxHxN
Huntresa
Huntresa
n smikle wrote:For anyone who can answer. Why is the car called CT-05??? was there a CT-04 that was scrapped or what? Or did Marrusia purchase the Ct-04?
Cause their roadcar will be/is called CT-04.
rssh
Has anyone noticed a different front wishbone geometry? The mounting point of the upper and lower wishbones aren't in horizontal layout (0 degree)but look more like 30 degrees, Are they trying to induce more airflow to the undercut in sidepods using wishbone as flow directors.
aral
aral
26
n smikle wrote:They must have tried to fit it with the turbo on. At Redbull they fitted the engine first then the turbo and anciliaries.
All Renault teams (and I presume all other teams with different engines) are provided with an accurate fully built sample of their engine. but looking at the "design" of the caterham, it would appear that different designers worked on different areas, so probably it was the ancilliaries such as rads, coolers etc, that caused any fitment problem.
Rikhart
Rikhart
Re: Caterham CT-05 Renault
I cant see this car being faster than gp2 cars anytime soon. It looks like a cargo boat, and has the detailing of one.
Cuky
65
Because this (Caterham Aero Seven) is designated CT04
Fernando-Alonso
Fernando-Alonso
Nobody noticed the pull-rod suspension?
EDIT: Sorry, didn't saw the post above mine. :roll:
aral
aral
26
Fernando-Alonso wrote:Nobody noticed the pull-rod suspension?
use of pull rod was revealed about 10 days ago!
Holm86
245
And funnily enough Scarbs dismissed that rumor back then :-)
Forza
238
Jerez T01 - Day2 - AMuS
HiRes via F1.NL
JDC123
JDC123
30
Why are the internal suspenesion parts on the caterham sticking so far out from the chassis. I have never seen anything like this before. This must mean changing the front wing will be much slower?
