Williams FW36 Mercedes
triptube
triptube
Re: Williams FW36 Mercedes
Very interesting design, the exhaust in the upper area by the gear, or gear fairing to lead. =D>
LookBackTime
LookBackTime
472
Williams FW36 - Österreich GP
trinidefender
trinidefender
317
hardingfv32 wrote:1) Do you think that the tail pipe must be assemble with the transaxle?
2) What is the external device around the tail pipe?
Brian
I assume you are talking about the monkey seat rear wing. That helps to generate a few extra points of downforce. It also seems to be used by some teams to aid to turn the airflow in this area to aid the diffuser and/or reducing the sensitivity on the rear wing by change the apparent angle of attack on the rear wing.
Pilatus
22
hardingfv32 wrote: 2) What is the external device around the tail pipe?
Brian
Electric heater.
Probably they need to heat tail pipe for easier assembly.
LookBackTime
LookBackTime
472
Austria 2014 - Thursday (19.06.2014)
gary123
Williams shows a refinement in the rear: if McLaren has sparked a great clamor in the winter for the rear suspension to "shutter" that is not giving you the results that engineers Woking expected, it is interesting to note, however, that the solution Pat Symonds engineers have taken on the arm of the rear toe FW36. The design of the lever is neutral, but in the vicinity of the outlet of the brakes become a real flap, as if it were an element of the aerodynamic duct bracketing.
Source: https://translate.google.it/translate?s ... edit-text=
roadie
39
Yeah I noticed that on Thursday with some of the shots of the car. I can't recall it being done before?
The FW36 needs all the rear downforce it can get to help with traction events, especially on worn tyres.
trinidefender
trinidefender
317
So with Williams new found turn of speed in Austria can anybody point out some updates that they have seen on the car? Or have all the updates been happening under the skin away from prying eyes?
djos
113
Awesome job by Williams and Massa + Bottas to lockout the front row!!! :)
I heard that Mercedes had finally shared their "Qually engine mode" with the other Merc powered teams so I'm guessing that helped combined with their recent upgrades.
"In downforce we trust"
Cam
45
djos wrote:I heard that Mercedes had finally shared their "Qually engine mode" with the other Merc powered teams so I'm guessing that helped combined with their recent upgrades.
If that's true, that's both bad and great I think. Great that it's more evidence that "it's the engine stupid" and bad that it's more evidence that "it's the engine stupid".
― Socrates
tony77g
tony77g
36
was already present at the GP of Spain
Image[/URL][/img]
gary123 wrote:http://www.omnicorse.it/img/articoli/ev ... _alare.jpg
tomazy
tomazy
205
Williams had the same solution allready last year: http://i.imgur.com/51QkNza.jpg
siskue2005
70
djos wrote: I heard that Mercedes had finally shared their "Qually engine mode" with the other Merc powered teams so I'm guessing that helped combined with their recent upgrades.
Source plz?
I'd like to see that one too, because that would be pretty low.
