I took the RB releases to mean that they have much confidence in the repeatability of their mass flow model and observed the shift against the mass flow sensor, i.e. “We had a fuel-flow sensor that was fitted to the car that we believed to be in error, and therefore based our calculation on the fuel that the injectors were providing to the engine, which is a calibrated piece of equipment that is consistent and standard across the weekend that we've seen zero variance in." Given a stable timebase (in the ECU) and repeatable injector motions (according to his claim) one would hope for consistent fuel flow against the model, otherwise you would see variance in other engine parameters. Granted, this estimation of mass flow depends on the some more measurements just as the velocity measurement of the ultrasonic. I understand there are many things at work at the fuel injector itself...shift time, fuel inertia, fuel viscosity, pressure differential across the nozzle, maybe a dozen more?bill shoe wrote:Yes. Anyone who says they "know" the true value of a mass flow to a high precision by measuring it indirectly has never tried to repeat the measurements themselves. RB upper management may think they know, and they don't. I suspect RB engineers with more sensor experience are a bit red faced at their team's press releases.
To be sure, this probably puts the instrumentation guys on the spot...
