I seriously think they do have an automated system. Not certain, but I've heard from several sources that they do. I could be wrong, though.scarbs wrote:To my knowledge F1 cars "do not" have automatic extinguishers, the driver and the marshalls each have a trigger (loop or button). But due the high G loads and heat within an f1 car no method of automatically setting off the extinguisher was ever found.all the cars have automatic exstinguishers
I hear what you're saying, but the weight is on the word "also"scarbs wrote:14.2.2 There must also be an exterior switch, with a horizontal handle, which is capable of being operated from a
distance by a hook. This switch must be situated at the base of the main roll over structure on the right
hand side.
It isn't as such a proof of the non-existance of an automated system.There must also be an exterior switch
I'd hate to sound like a broken record, but that doesn't exactly prove the inexistance of the automated extinguishers. It just states what is mentioned above; the car has to have a mechanical way of extinguishing the fire.Monstrobolaxa wrote:14.1.8 Any triggering system having its own source of energy is permitted, provided it is possible to operate all
extinguishers should the main electrical circuits of the car fail.
The driver must be able to trigger the extinguishing system manually when seated normally with his safety
belts fastened and the steering wheel in place.
Ok, you win, damnit! It is indeed a tricky environment to put an automated extinguisher in (imagine a false alarm in the middle of the race!). I guess it just isn't worth it for the manufacturers, though for the FIA and general safety it would be nice. If a car catches fire after a crash and the driver is unconcious, then the extinguishers would go off immediately, rather than when a track marshal gets there with the aforementioned pole. Especially if the car is flipped over the switch at the side of the airbox can be pretty hard to get to, not even mentioning the possible flames. This area of the FIA regulations could use a little modernization, the rules are way over ten years old on this.scarbs wrote:I just asked lifeline the main supplier of F1 extinguishers, the teams must only use a manual trigger (mechanical or electrical), There is no known automatic system for the reasons I previously described.
