Joseki
Joseki
Re: Honda Power Unit
For Fernando the update is "very small", Hasegawa says it's worth about 0,1s.
GoranF1
GoranF1
155
godlameroso wrote:
24 Aug 2017, 18:15
GoranF1 wrote:
24 Aug 2017, 17:57
godlameroso wrote:
24 Aug 2017, 16:07
Maybe it belongs in the team thread, it seems now both Alonso and Vandoorne are getting the updates, except Vandoorne is getting a small reliability tweak.
https://www.motorsport.com/f1/news/mcla ... pa-944158/
How can they update whitout penalty?
Appendix 2 of the technical regulations, the table marked article 5.22, everything that's in yellow "EXC" can be freely changed without penalty, as you can see there's a lot of leeway.
You can change the wastegate, and blow off valves which let you control the MAP, and EBP, more precise control of electric super charging mode, and can help make recovery and deployment more efficient.
You can also change:
PU Engine air inlet system from plenum entry to cylinder head (e.g. plenum, trumpets, throttles)
as well as
PU exhaust system from the engine exhaust flange up to but not including the turbine or wastegate exit tail-pipe.
Pretty big change
PU mounted fuel system components: (e.g. High Pressure fuel hose, fuel rail, fuel injectors, accumulators)
Somewhat relevant
Main PU oil tank, catch tanks, and any breather system connected to them and associated filters, brackets, support, screws, nuts, dowels, washers, cables, tubes, hoses, oil or air seals
These seem important
MGU-K mechanical power transmission components and mounting accessories
MGU-H mechanical power transmission components and mounting accessories
And the list goes on, power unit ballast, pumps, hoses, heat exchangers accumulators, servos, hydraulic parts.
8kw improvment as usual....;)
Craigy
84
Joseki wrote:
24 Aug 2017, 18:24
That's 4.5s over a race distance. Not nothing.
GoranF1
GoranF1
155
Joseki wrote:
24 Aug 2017, 18:24
What he said about other 2nd driver's update?
about .1?
bigblue
The Belgian will also benefit from a small reliability update, which did require a component change that Honda is no disclosing, with Honda calling it 'spec 3.6'.
Sounds like it's the same as Alonso with one reliability difference, about which they're being quite secretive !
fellowhoodlums
fellowhoodlums
Sounds like Honda are on a roll after Spec 3 was introduced in FP at Baku. Clearly it's resolved a lot of issues that prevented proper development of the engine. Spent most of the time firefighting issues until then.
Now it's update after update and they clearly feel they can get ahead of Renault before end of year. McLaren then challenging with RBR for a possible podium.
You get ahead of Renault, you ain't gonna lose Alonso.
dren
226
If Honda surpasses Renault, Mclaren may lose Honda.
I'd guess the reliability upgrade is something for the MGUH just based on this PU's history, but who knows?
Honda!
MrPotatoHead
Craigy wrote:
24 Aug 2017, 13:21
ispano6 wrote:
24 Aug 2017, 13:15
Perhaps it wasn't so much the physics of multi cylinder scaling but more so a change in the structural properties of the 2017 car from the 2016 specifications that had unforeseen side effects. The floors seem to be rather flimsy compared to past generation cars.
In 2017, F1 floors aren't particularly structural - they are really aerodynamic bodywork.
The structure of the car is monocoque to engine, engine to gearbox and everything else bolts onto those, including the floor.
Not structural but they do undergo FIA strength testing because of previous dubious floors.
Craigy
84
MrPotatoHead wrote:
24 Aug 2017, 23:28
Craigy wrote:
24 Aug 2017, 13:21
ispano6 wrote:
24 Aug 2017, 13:15
Agreed, that's why they are not 'particularly' structural.
For at least one of the teams, the floor is actually made in one piece - their autoclaves are very big (walk-in). It's not bendy but it does sit on a jig with about 12 fixings...
447
Craigy wrote:
24 Aug 2017, 20:18
Joseki wrote:
24 Aug 2017, 18:24
70-80s more to go....
etusch
131
Craigy wrote:
24 Aug 2017, 20:18
Joseki wrote:
24 Aug 2017, 18:24
That could give first points to SVD Silverstone.
Joseki
Joseki
The speeds of the car are depressingly unsurprising, both with the high downforce or the low downforce set up.
63l8qrrfy6
63l8qrrfy6
368
They could be running any engine in FP, doesn't have to be the latest.
It's FP1. They will be running it tuned down \:D/ \:D/
