There is no benefit at the rpm where the variable trumpet is set to the same length as the previous (fixed length) trumpet. (There may be a miniscule benefit if the fixed trumpet engine included some design compromises to make it less peaky.)
At RPM either side of this, the cylinder filling will be slightly better with the variable system (benefit increases as rpm departs further). This will allow a reduction in MAP and therefore less compressor power requirement, leaving more energy available to the MGUH.
So - raw crankshaft power does not increase but the H and therefore the K will see a power increase.
