Roostfactor:FIA gave Honda a token back for the engine block upgrade.So Honda still has 2 tokens left.
Interesting, I wander if Honda will reconsider another update this season.
it's not enough. You need 3 tokens for modification on chamberhemichromis wrote:Did someone on here mention that 2 tokens is enough for a combustion upgrade?
I don't recall a precedent for any of them doing that in the past. Interesting idea.turbof1 wrote:Or, they simply used the token to get the update quicker into the field, without having to wait for approval from the other manufacturers. Afterwards, Honda might have applied for it to be converted to a reliability upgrade.
Hasegawa actually said this before though.turbof1 wrote:Strange. I really don't see Honda making a judgement error whether an update requires a token or not, and furthermore why would the FIA bother to dispute that?
I'm really guessing, but my reasoning would be the update indeed did not require a token, but Honda wanted to keep it hidden. When using tokens, the changes do not have to spread to the other manufacturers for approval, which otherwise is needed if using updates for reliability purposes.
So this is in the, get this, Honda Power Unit thread. Along with a almost 2 dozen of pages of chassis talk which really, really do not belong here.PlatinumZealot wrote:So gow do you explain this?Sasha wrote:Suzuka is all about being smooth and losing zero speed in fast and mid speed corners.So a great chassis(keeping it level to the ground at all times) and PU drivability(still must have great ICE power and great HERS at the sametime, KERS not as important at this track) is a must here.
Mclaren chassis doesn't keep level all the time and eats rear tires so sucks on mid to fast corners.Honda PU is behind everybody on drivability.
http://i.imgur.com/JGHtasS.jpg
