harjan
harjan
Re: Honda Power Unit
ESPImperium wrote:
29 Apr 2017, 23:21
With all this lack of ERS, the tyres are not getting stressed due to lack of downforce from lack of power. Again cyclic as a package.
Could you clarify this please? 1. Until now I've only heard that they lack ICE performance- but also ERS? 2. Do you mean tires not being stressed because they run lower downforce levels? If they do run lower df levels then yes you can expect them to make 'exponential' gains if the performance goes up. But otherwise there's no reason to believe a more powerful engine would stress the tires more- they're all grip limited.
As for Alonso's 2.5 sec number. You can bet that it's fairly accurate, it's most likely a McLaren engineer that did that calculation. However.. It's only 80% of the story. Because IF they lack cornering exit speed (lower apex speed or exit speed as a result from suspension or downforce) that speed difference also adds up over the entire following straight.
Whatever happens this Honda project is doomed. Let's say that they'll find the right direction and come to Merc 2016 levels in 2017. Then it will take another 1-2 yrs before they're on par with the rest. McLaren will be long gone to another supplier and we'll have a different engine format looming around the corner. So Honda should have stuck with their 2016 layout and work on evolution vs revolution. Just like Renault and Ferrari have done.
ollandos
ollandos
http://prntscr.com/f2dwvn
1 sec increase the gap from the top on 2017 vs 2016 ....and the smaller gain of all teams...1st renault 2nd ferrari ...the 1st sector its similar to last year ..and the top 3 all gain around half second ...look like the others engines have the same developent gains ...
Singabule wrote:
29 Apr 2017, 17:39
Hmmm, Alo top speed no more than 10kph lower than lance Williams with lowest drag, wonder where the 3 sec Come from :lol:
There are losing ~7kph over 3.2km of the track, and not making it up in the corners, that's where.
Andres125sx
harjan wrote:
30 Apr 2017, 00:03
Let´s imagine a pathetic situation to then state they´re pathetic :roll: :lol: :lol:
Some people... #-o
Redragon
19
it is official Sauber will have Honda engine next year
harjan
harjan
Alonso out in warm up lap. Unbelievable.
Happy to hear Mercedes / McLaren deal is done and dusted.
Chene_Mostert
-2
! Honda !
"Science at its best is an open-minded method of inquiry, not a belief system." - Rupert Sheldrake
Chene_Mostert wrote:
30 Apr 2017, 14:06
! Honda !
Well they're at least faster than 2016 Ferrari engine. That is the difference between 2016 and 2017 engines.
Chene_Mostert
-2
godlameroso wrote:
30 Apr 2017, 15:42
30 Apr 2017, 14:06
! Honda !
Slowest of 2017 engines, Honda should not live in the past.
Let's hope they have an all new PU for Alo @ Spain.
I wouldn't be surprised that they already new there was a problem and chose not to change the PU. Using another PU, knowing that their wasn't a chance of getting into the points, would be a waste.
etusch
131
At this track even ferrari engine not good enough at straights. Renaults gap much bigger. In this conditions Honda's situation is not worse than before.
Merc won this race with just straight line speed
Chene_Mostert
-2
30 Apr 2017, 15:48
godlameroso wrote:
30 Apr 2017, 15:42
30 Apr 2017, 14:06
! Honda !
Just facing reality...
ronanharris09
ronanharris09
etusch wrote:
30 Apr 2017, 16:38
Here is the results
[tweet]https://mobile.twitter.com/AlbertFabreg ... 571586?p=v[/tweet]
When it comes to 💻 science 💫, what I much about it 💢 is analyzing the 📉 📊 👌.
30 Apr 2017, 16:39
30 Apr 2017, 15:48
godlameroso wrote:
30 Apr 2017, 15:42
No doubt they're not good enough, I still don't think they'd be anywhere near the front with the chassis they have.
The engine update will cut the deficit to the current Renault engine by half, so the total deficit to the top will be cut down to ~2 seconds, maybe a little less depending on what McLaren can do for the chassis. The best that McLaren/Honda can hope for is a 1 second deficit to the front runners by the end of the year.
Chene_Mostert
-2
godlameroso wrote:
30 Apr 2017, 16:59
30 Apr 2017, 16:39
30 Apr 2017, 15:48
Sure hope so this time around, McLaren does not belong in this position.
