Hmm. I have raced several F1 and Indycar champions in FF and F3 championships. They beat me by a country mile, but I still have a lot more driving experience in single seaters than most people. What have you done?prince wrote:It is a bit unfortunate that, like many of my friends, you probably only watch newspaper to see who won and who has how many points. For most of the other people who follow F1, follow every inch the car is moving, the reality is different.
Could be several reasons. Bad driver management. Bad input from the driver team to the engineering team for 5 seasons. Choosing money over performance. Choosing prestige over performance. Perhaps not being the "Best Driver". Whatever the reasons, after 5 seasons it is not "luck", it's "choice".prince wrote:1) What do you call it, when the Best Driver of the grid has been stuck with a team that is producing dogs for the last 5 seasons?
Could be several reasons. Bad preparation. Lack of testing. Marginal technical choices. Weak race engineering. Poor team management. Garage politics. Making enemies when you need friends. Whatever the reasons, probably not "luck" if it is happening over and over again to one car. My mate H at Joest would probably say it is all preparation.prince wrote:2) What do you call, when engine fails before the race starts, when MGU-K fails when chasing for top position and when break fails when challenging for pole, when the team mate causes yellow flag and denies an opportunity to try for a crucial pole, and most of pit stops takes more time than his partner?
I don't deny (and never have) that Lewis is talented. But as Allan McNish says, and I agree, there is no such thing as luck in motorsport:-prince wrote:On the other hand Nico has been doing a great and consistent job, with only one DNF. The net result is still a 14 point deficit for Lewis.
Unfortunately that seems to be the standard MO in the Ros/Ham argument. Nobody wants to hear this, but its been fairly clear that the drivers are fairly equal.gilgen wrote:770 posts all on one is better than the other....all going round in circles! sounds like school kids saying that their dad is bigger than your dad!
it is all immaterial. just let the two race each other and wait to see who comes out top at the end of the year.
I don't think that is called luck. In poker and stats that is what you call "variance", assuming a random distribution. And each outcome is an independent result.Miguel wrote:Luck exists. It is the pixelation caused by the necessarily finite size of a statistical sample. Tolerances exist. It is perfectly feasible that, over one season, a driver may be hit with more reliability issues than his teammate through no fault of his own. Expecting a perfectly balanced list of mishaps between teammates shows a lack of knowledge of statistics.
Whatever argument you use against one then it can be used against the other. For example you say car advantage has helped Lewis, but you have just given an example of how car advantage helped Nico - in china he had a poor start and dropped to 6th then managed to get 2nd with no telemetry.iotar__ wrote:Quite fair =D> but IMO pointless exercise. Australia is a very big assumption and not equalised by Silverstone, theoretical win for NR was much closer there, lead after first corner/lap and after first pitstop. Just to nitpick and if we're talking fairness and driver's performance:
- Hamilton's dirty chop in Bahrain - without Rosberg stopping on track (not 50/50 more like 100-0) it's double DNF -7 LH, or something random
- Car's advantage helped more Hamilton after inexcusably poor qualifying in Austria and GB
- China - telemetry
It is called luck! There is no reason you need to assume identical behaviour from the two cars in order to conclude that one driver has had more luck than the other if he has had less DNFs. In racing there are a lot of circumstances that you can't control yourself and if these circumstances favour one driver more than another, luck is the appropriate word to use.SidSidney wrote:I don't think that is called luck.Miguel wrote:Luck exists. It is the pixelation caused by the necessarily finite size of a statistical sample. Tolerances exist. It is perfectly feasible that, over one season, a driver may be hit with more reliability issues than his teammate through no fault of his own. Expecting a perfectly balanced list of mishaps between teammates shows a lack of knowledge of statistics.
People choose to call it luck. I think Sam Goldwyn got it right.Stradivarius wrote: It is called luck! There is no reason you need to assume identical behaviour from the two cars in order to conclude that one driver has had more luck than the other if he has had less DNFs. In racing there are a lot of circumstances that you can't control yourself and if these circumstances favour one driver more than another, luck is the appropriate word to use.
Here we are at the crux. My view is it is precisely in Hamilton's control, because he chose to drive that way, while Button did not. He choose a path, a setup, a style, a strategy - whatever - that is inherently more risky, and that almost by definition will lead to more failures of one kind or another. So what is "lucky" about that outcome, with luck being defined as an outcome decided by pure chance rather than ones actions?Stradivarius wrote:My point is perhaps more clear if we look at Button and Hamilton. Hamilton is an aggressive driver who often qualifies well and runs close to the front of the field during the race. Button doesn't qualify as well and usually runs a bit further behind in the field. This is true now as well as when they were both at McLarren. The consequence of this difference is that Hamilton must expect to loose more points than Button due to technical failures and other things outside his control."
I agree you have to look at EV and ρ to determine likely outcomes. I may well spend a few minutes looking at it one day. I just don't agree it is luck/pure chance. If that were true then he was equally lucky winning 4 in a row, right? No, that was skill....Stradivarius wrote:At the same time, Button can expect to gain more places due to other driver's misfortune. So if you see that they both have lost 30 points this way, you can't say that they have been equally unlucky. Actually, this would indicate that Hamilton has been more lucky than Button, since you must consider the outcome and compare it to the expectancy.
I agree with that, and I also think the attitude of the end user to mistakes has impact on the end-to-end process. If a driver cares, follows up mistakes, finds out why they were happening, perhaps even shows up in that dept. one day to ask about what happened, the process - a large part of which is attitude - adapts. I have seen this on my own race cars. I once drove in the same team as a young hotshoe who was always having mechanicals and came back to the pits moaning and bitching then went off with his girlfriend for lunch. I usually hung about the garage, and quite often I would spot a junior missing something simple, like not torquing nuts, leaving cables astray where they might rub or melt. I would just ask him - did you notice xyz? - and when he noticed me noticing he at first got the hump then started to double check himself. It didn't make me any faster but I rarely stopped through car failures, whereas the young chappie in the other car kept having basic failures, his wealthy dad who was stumping up 25K a weekend stepped in, blamed the team, it all got messy, blah blah blah, usual motorsport horror story. Last time I saw that mechanic he was working on a Williams on TV, that was several years ago.marcush. wrote:Who receives the part and when the Thing Fails is another story but to assume the product Nico and Lewis are receiving sunday morning is 100% the same is simply not possible.
Yep. Some drivers just push a car harder. Some times they get away with it, sometimes not.marcush. wrote:Still some People have what one has to call mechanical empathy .Those type of humans can carry a wounded machine very very Long indeed at considerable Speed and others seem to have a Talent for breaking bits you always thought of as bulletproof. It´s hard for those to accept their lack of feel and sympathy for the mechanical side of things and as an engineer you´d better Beef up the car instead of trying to convince your hero he Needs to sharpen his Manual skills..
Let me ask you this:dans79 wrote:I would call a brand new break disc exploding bad "luck".......................
