Pirelli 18 inch tyres - visualization
FW17
168
Re: Pirelli 18 inch tyres - visualization
Tim.Wright wrote:These guys have had carbon wheels homologated for road use for a few years now:
http://carbonrev.com/
Lambo Forged Composite wheels may be better
McMrocks
McMrocks
32
Re: Lotus E22 Renault
It doesn't look too bad. Do they use a different suspension or different suspension arms (wishbones)? Everybody said that they need to strengthen the suspension because the tyre doesn't help the suspension anymore. So I'd be surprised if they just stuck that tyres to their normal suspension.
Now that looks great.
zoro_f1
-2
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
The FIA should mandate them alongside with the FRIC Ban for Germany. :D
They are using the normal brake hubs
j2004p
j2004p
Get these on for next season, they look great!
Aside from (IMHO) the aesthetic improvement I can only imagine that one of the key benefits will be better predictability in the lateral flexing of the tyre through a corner, less height to the sidewall and all that.
The suspension will surely need to be softer too as I remember Martin Brundle saying that as much as half of the cars ability to absorb bumps came from the flex in the sidewall.
jayeshrc
jayeshrc
McMrocks wrote:It doesn't look too bad. Do they use a different suspension or different suspension arms (wishbones)? Everybody said that they need to strengthen the suspension because the tyre doesn't help the suspension anymore. So I'd be surprised if they just stuck that tyres to their normal suspension.
i think the suspension is strong enough, (i dont believe the flexing of sidewalls added that much in terms of strength to the suspension per se) they probably need to strengthen it if they want to continue bumping into each other with the new tyres?
Also, compliance would be better with less sidewall flex to factor in, so i'm sure teams would (in time) welcome the change. But till then, its back to the drawing board for the suspension guys..
..and brakes and aero (and engine mapping because of the larger overall diameter)
Correct me if i went wrong anywhere
George-Jung
George-Jung
WilliamsF1 wrote:
George-Jung wrote:are they allowed to increase brake-disc size?
What is the necessity for that?
Because racecar..
krisfx
krisfx
Because racecar..
Those tiny little brake disks look daft on the massive alloys?
gray41
So ugly.
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
jagunx51
185
http://www.tunersandmodels.com/wp/wp-co ... oncept.jpg
Yes....all they need now is a proper wheel :wink:
jagunx51
185
Those tiny little brake disks look daft on the massive alloys?[/quote]
and that empty space between rim and brake could create so many wake & drag
WaikeCU
I think with these tires, drivers will tend to avoid wheel to wheel action. If we were already using these wheels then I think Rosberg would have had a DNF in China after turn 1 and Hamilton would probably have had problems too last weekend after that wheel to wheel action with Vettel right after the start.
geraldix
geraldix
It looks AWESOME. Makes the 13" rims look like toys. Should be implemented ASAP, along with the jet-like windshields FIA has been testing!
