They might neuter ERS, too
FW17
168
Re: They might neuter ERS, too.
dvstwig wrote: What!?
By that logic, I could travel 200km/h in a 60km/h zone, so long as I only travel 60km during the hour...
Then, if the police pull me over when I'm doing 200, I could just say "but officer, if you sampled my speed at the beginning of this hour, I was only doing 60km/h, and at the end of this hour, I'll only be doing 60km/h"
Maybe we should start having speed limits posted as metres per second?
These guys must be some aspiring lawyers trying to pull a fast one
xpensive
xpensive
214
MOWOG wrote: ...
The only way to break Bernie's death grip (some legal types might say (mort main) is to drive the value of FOM to zero.
jz11
jz11
19
dvstwig wrote:
CBeck113 wrote:@WilliamsF1 & Holms86: Not quite, since what you're naming are maximums - limits - and therefore naturally a boundary. The FiA did not specify under which condition this stipulation must be met, and left too much room for interpretation (once again). As a team you have to exploit every loophole you can find, or you don't win.
And yes, 100kg/hr is not equal to 27.7 g/s, and 27.7g/s will always be 100kg/h. Why? In saying 100kg/h, the sample is at each hour, while when saying 27.7g/s, the sample is every second.
What!?
maybe we should, because there are enough people around who cannot "connect" the speed on the speedometer to a braking distance required for them to avoid X or Y object that suddenly appeared before their car - which is the basic reason why there are speed limits around
will it happen - no, reason - same one because of which there still are miles, inches, stones, yards etc. used in some places
I had this argument before here and even PMing to a user who thinks I fail at basic math and don't understand units and rates, on paper without any context the numbers 100kg/hr and 27.7gr/s always mean the same thing, but do they when you talk about the actual flows that you measure? Because there is no absolutely linear flow, something will always bounce and pulse somewhere, so for all and every flow that, when measured with a crude enough instrument, you will get the same reading, does that mean the flows are equal? NO! if you go into fine enough detail, you will start to notice that one of the flows has more linear than the other, and then 100kg/hr still is true for both, but 27.7gr/s not so much - because we care about the actual flows, not the number we represented it with on the piece of paper
and that is the reason why there is a clarification to the flow rule which red something like "must not exceed 100kg/h", but now reads "must not exceed 100kg/hr when measured over a period of 5ms"
there is no such thing as instant speed or instant flow in real world, it only is there on the paper in your formula that lost its context, there is no measurement device on the world that can take instant measurements of anything, everything is some sort of aproximation over a period of time - and that thought must never EVER be lost, without time component those measurements are meaningless, especially when you measure something that is quite disturbed and is fluctuating - what period of time to use then - you will ask - and the answer is - time period relevant to the cause of the measurement!
next argument - use relevant units when you want to convey to the user the precision of the measurement of anything, nice round numbers look good, but if you care about milliseconds and thousands of the grams - use relevant units or specify time period (which they did at the end)
CBeck113
CBeck113
51
Thanks jz11, I didn't have the patience to explain it so clearly - well done! But I do have a better example: Oldtimer ralleys!
For those not familiar with the concept, the cars have a route which they must travel, and have to do so with a time Goal, which is also an average Speed in km/h or mph. The organizers either calculate this Goal or drive the route to determine what it should be. The contestant closest to this Goal wins. Now, the contestants can use maps and stopwatches (some may even allow GPS, but I'm not sure), and have to calculate how long they'll Need to finish the course. They will also calculate check points, to determine if they will be on time or not.
According to your understanding of 100kg/h limit, they can only travel the speed limit in order to reach the goal, and if they fall behind, could never reach it. Reality says that they will drive faster for a period to reach the goal time.
Who's right here? We all are - only when a team sees an advantage will they argue like I am - or have you seen someone drive through the pits with 200km/h, and then stand still for a few seconds to compensate? Nope, won't happen...[also because the measurement method has been clearly defined (GPS & Speed trap - defined measurements & sampling intervals)].
Pierce89
CBeck113 wrote:Thanks jz11, I didn't have the patience to explain it so clearly - well done! But I do have a better example: Oldtimer ralleys!
Ok you're talking average rate not max rate, but a rate is a rate.
kptaylor
kptaylor
So any additional news on this potential "ban"?
mrluke
mrluke
Pierce89 wrote:Ok you're talking average rate not max rate, but a rate is a rate.
All rates are averages. Its the average amount of something per unit time. You cannot calculate a rate of change from a single data point, you need at least two so that you can average them to get the rate of change.
The second thing to remember is that the rules are really a contract and are interpreted as laws. As such the important thing is what is actually written rather than what do you think they meant.
If you had a contract to deliver 60 apples an hour, you turn up an hour later with 60 applies and the recipient say thats not acceptable, you were supposed to deliver one every minute and because you turned up with 60 at once you are in breach of contract. You would respond that if they wanted one a minute they should have said that in the first place because that is not what you signed up for.
