riff_raff wrote:Pratt & Whitney won the production contract for the F-35 engine. RR/Allison won the contract for the lift fan and drive system. The 30,000hp lift fan is driven off the engine fan shaft, which is driven by the LP turbine stage. Most of the vertical lift in hover comes from the counter-rotating lift fan, and almost all the rest comes from the swivel nozzle on the engine exhaust. A tiny amount of lift comes from the wing tip roll control nozzle flows.
The clutch wear from a vertical TO is not that great because the relative speeds of the engine fan and lift fan at idle are not that large, the amount of torque transferred is lower, and so the amount of slip produced to synchronize the fan and engine speeds is low. The clutch wear from engaging the lift fan prior to hovering and a vertical landing, is reduced by the windmill effect of airflow passing over the lift fan helping to spin it up.
A well considered response riff raff.
P and W did indeed get the contract.
The RR engine is a better engine however, although that will be difficult to prove I suspect.
Your description of the fan drive is fine, are you trying to convince us that increasing the combat payload to maximum during vertical take off places no increased load on the clutch or the turbine?
Are you saying that there is no need to slip the clutch during this flight condition?
Of course the relative speeds of the turbine and fan are going to be similar at idle!
Can you explain how the fan output thrust is modulated during a maximum payload vertical take off.
I understand the electronic control system has to vary the various component rpm to maintain flight stability.
It is of course essential to balance the lift fan thrust with the thrust from the swivel tail nozzle.
How is this done at full vertical take off payload?
Might be a bit difficult to throttle the turbine when it is at max thrust burning holes in the ground.
Yes I have seen the huge concrete pads being built for landing the thing on.
