Blackout wrote:Log manifolds + classic turbo layout => the compressor is sandwiched between two very hot manifolds.
Interesting.
850hp => 43% thermal efficiency which is hard to believe (Williams confirms in the last F1 racing that fuel heat content is around 43MJ/kg)
No offense, but you need to check your math.
Assume LHV = 44MJ/kg. This is the same LHV of diesel, which is 6% higher than petrol and a good guess for F1 fuel. They may go higher, but not astronomically...
Ideal combustion power: (44MJ/kg) x (100kg/hr) x (1 hr/60min) x (1min/60sec) x (1000kJ/1MJ) = 1222 kW
850hp X 1kw/1.34kW = 634kW
BTE = 634 kW / 1222kW = 51.9%
That said... it's cheating to use the KERs recovered power for BTE calculation (maybe you already backed that out from the 850hp), so let's say the engine without KERS makes around 700hp, in which case the calculation is same as yours around 43%, but I wouldn't be surprised if the 2015 ICE + MGU-H are above 700hp...
