Lotus E23 Mercedes Speculation Thread
geraldix
geraldix
Re: Lotus E23 Mercedes Speculation Thread
The side inlets beside the roll scoop make it look chunky as hell.
Very interesting "S" RW support coming out of the engine cover.
Sidepods look very fat, with major bump towards the rear. Overall packaging looks lame...
Vary
Vary
Optical effect or the rear wing pylon is "asymmetric" like last year?
Shrieker
Glad that it doesn't have a horrid nose like the williams...
-Atatürk
dren
226
Vary wrote:Optical effect or the rear wing pylon is "asymmetric" like last year?
Looking at both 3/4 views, I'd say it is more like the Y-lon the other teams used last year.
Honda!
geraldix wrote:The side inlets beside the roll scoop make it look chunky as hell.
I think it's neatly packaged.. it's like shrink warp compared the old parachute pants that was there before.
The comments about the car looking like it belongs in a lower formula is intriguing... I sorta see why people think so, but it lets me think to myself, what makes a formula 1 car so much visually different from lower formula cars?
no, that's just the angle. just look at a couple shots to compare. it has a S-curve like said. it is not assymetrical as it seems.
astracrazy
astracrazy
31
ye i like that, tidy and simple.
sidepods look quiet small actually imo, just bulky at the front
BanMeToo
BanMeToo
It's an illusion. In each 3/4 pic it looks like the pylon is assymetrical toward the 'far' side of the car, but it can't do that in both directions! Unless they've figured out a real fancy flexy-pylon trick :wink: 8)
edit: woah, we're all on the same page then!
The Lotus looks more 'simple'. I really genuinly like that, actually. I actually say i think there is good potential here, it looks like it's a solid base for a lot and a lot of development. The lotus actually reminds me of 2009+ Renault F1 cars.
dren
226
The nose doesn't look to bad. It looks to have a slight hump under it to probably create a little low pressure in the area.
The team spent some time to create such a short nose. Similar FW attachment like the Williams.
The sidepod exits look a little higher than most teams last year, but not quite as high as the Mclaren's were.
edit...forgot Lotus switched PUs...
Honda!
Vary
Vary
Actually, in the first 2 photos (on Lotus website) the pylon is one time on the right, the orher on the left of the exhaust... Very interesting
It's fixed to the engine cover like the RB10.
GoranF1
GoranF1
155
dren wrote:The nose doesn't look to bad. It looks to have a slight hump under it to probably create a little low pressure in the area.
The new Renault PU must really have some high cooling requirements.
Good thing Lotus use Mercedes then....
Lorenzo_Bandini
Lorenzo_Bandini
They use Mercedes engine this year :)
dren
226
Well ---! I knew that. Thanks for the clarification.
Honda!
