Williams FW37 Mercedes
edu2703
edu2703
32
Re: Williams FW37 Mercedes
Low-drag front wings?
trinidefender
trinidefender
317
No, the wing adjuster is just used to flatten out the wing into the low drag, low downforce setting. You will see that in a lot of the pics when the wings have just been Unboxed from transport.
Carinni
Carinni
But it is not the Mercedes style new front wing, so it is the lower drag version, the old version
Carinni
Carinni
They used this old version front wing in Austin too. Don't know why give up the new one
f1316
f1316
78
Smedley mentioned taking appropriate measures to even out altitude effect on the engine - what he called the same kind of things they do in Austria/Brazil but just to a greater degree :
http://m.autosport.com/news/report.php/ ... xican-test
Probably running lower drag is part of that
trinidefender
trinidefender
317
Carinni wrote:But it is not the Mercedes style new front wing, so it is the lower drag version, the old version
Just because it is the old version doesn't mean it is lower drag version.
Less dense air means a lack of down-force which means the tyres will slide more. So cranking on down force is a tricky balance against cutting drag to get speed on the straights.
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
Craig Scarborough ‏@ScarbsF1 10m10 minutes ago
Craig Scarborough Retweeted Albert Fabrega ES
Williams cockpit-side cooling slits not raced since Malaysia
Carinni
Carinni
As far as I know, the new version creates more vortex in order to creat more down force, and the cost is higher drag.
trinidefender
trinidefender
317
That is along the right lines but still a gross over simplification of the wing. The change will have more of an effect on controlling front tyre wake than this wing itself.
Controlling the wing's drag/downforce capability for the front of the car is mainly through the use of the inner flap adjuster.
Carinni
Carinni
So there is no obvious aerodynamic progress :cry:
Carinni
Carinni
LookBackTime
LookBackTime
472
Hail22
144
Mexico GP - Thursday
Gilles Villeneuve
