Rhodium wrote:i'm sorry, but my english is really bad.
i don't understand your answer.
Google is your fiend.. ..try typing movie quotes.. ..(with the quotes provided)..
yeah that would be interesting... though claimed point of limiting returns is around 23,500 rpms.Rhodium wrote:V10 Atmo 1000 hp, 30 000 rmp max, with traction control.
boring to see F1 slow in corner and tired to hear this noise...
for me...
You've pretty much knocked Ferrari out of the equation by specifying 5,000 units per year to be built.Moxie wrote:My intention here is to free up engineering development while at the same time allowing the engines to be relevant to consumers.
The engine block and heads should be available to the General public, with current production runs of 5,000 units.
The block should come directly from the mainstream production line. If a manufacturer wants special castings then 5,000 castings should be produced and made available in the cars they produce. (Cherry picking the best of those castings for use in F1 is acceptable). FOM should encourage cross marketing of its own brand by allowing manufacturers to use "F1" in the marketing of vehicles that include the F1 homologated block.
One manufacturer may choose to use a turbocharged, direct inject engine, while another manufacturer may choose another combination. As long as the blocks and heads are available to the public, it is all good.
Heads must also be produced for the general public, but they may be sold as aftermarket items. The 5,000 unit threshold still applies. Again, cross marketing of brands should be encouraged.
Pump gasoline (petrol) for all teams to be supplied from a single supplier that must be a chemical match to a station, randomly selected from the providers fleet.
Ancillary items such as turbochargers, ERS systems, are all open to experimentation and development.
The number of 5000 was not intended to be an absolute. Rather it was intended to represent the principle. I would think that at least 1000 should be produced. Admittedly, I'm am not an expert on automotive production numbers. I would hope that the production requirement is high enough that a manufacturer won't hire a shell company to buy all of the cars using the spec units, thus allowing them at great expense to engineer a block that is not truly worthy of road use.wuzak wrote:
True enough. The WCC is a competition of engineers. Give them roadworthy, production blocks and heads and let them engineer all the speed they can get out of them.wuzak wrote:Blocks and heads for road use will be bigger and heavier than those for race use, simply because they have to last far longer.
To be fair, only a few months ago there were many saying 900hp from the current V6T PUs would be impossible, so I can understand why the thought may be entertained, despite the practical limitations.J.A.W. wrote:R, you need to do some basic reading on piston engines to learn why your dream of "30,000rpm" is just silly for F1 racing..
..suggest you start with practicable piston speed limitations..
Well I like the 30,000 rpm limit because it makes the rev limiter mean piston speed calculation so easy!J.A.W. wrote:A couple of notable quotes - from those in the know - may be apropos in relation here..Rhodium wrote:V10 Atmo 1000 hp, 30 000 rmp max, with traction control.
for me...
1, "Tell him he's dreamin'!"
2, "Och laddie, ye cannae change the laws o' physics!"
