F1 now & then: engine vs aero formula pro/contra
giantfan10
giantfan10
27
Re: F1 now & then: engine vs aero formula pro/contra
Moose wrote:
Phil wrote:It's not all engine - but the engine difference is there...
Honestly, I think you're doing a huge disservice to all the non-engine engineers at Mercedes. They've built a car that's seconds clear even of the cars with the same engine, and of cars that are acknowledged to have an engine that's as good as theirs. Yet even with all of this, you still assert that it's all down to the engine.
Aside - ultimately, if FOM/FIA want equal engines, they can do it trivially. They approach all of the engine suppliers and say "how much would you charge teams per year to be the sole engine supplier", and then pick the cheapest.
LMAO if you think costumer teams have the same engine output as mercedes... you cannot be that naive
Phil
66
@foxhound
I'll admit I'm playing a bit of devils advocat here.
You are right, engines are an integral part of F1. The sport needs new engine manufacturers (or for the current ones to stay) and with the change in engine development, it's crucial that F1 also adapts to make the sport more relevant to what happens outside. The only problem I see is that engine development comes at a huge cost - so the token limitation is a necessity. It's not to prevent other teams from catching up, but to ensure that costs are kept under control.
I just see a lot of similarities from the times when we had two tyre suppliers. It's a problematic situation: Take Williams and Sauber. In 2013 under the V8s, Williams was in a mess and finished the year in the WCC 9th. Sauber finished 7th. That was during a period where all engines were give or take very similar in power output. Then in 2014, Williams propelled itself to 3rd and Sauber went off the grid finishing 10th. Now, the financial struggles Sauber had are well documented in 2014 - but the engine played a big role in that, just as it did in propelling Williams out of the midfield it was during years before. For a team like that [Sauber], having a clearly underperforming engine is a huge problem - and it's nothing the 300+ employees can solve, because it's solely in the hands of the engine supplier. Sure, their chassis brought problems too, but together with a not performing engine, the problem is exaggerated ten fold. Williams on the other hand, proved to be in a very formidable position; tyre wear and corner speeds on many tracks showed that they clarly were not at the top of end with aero, but they still managed to be very competitive on most tracks, finishing a strong 3rd.
So, out of the view from Redbull, who as a 4 times WCC and WDC team have always excelled at creating exceptional chassis with aero - how are they to solve the problem that lies exclusively with their engine supplier? It's a bit like running on worse tyres to your competitor.
And engine manufacturers don't run these teams, the teams do. We only have 3.5 engine manufacturers (I'm counting Honda as the .5 because they are only supplying their own team), but we have 9 to 10 teams depending if you count Manor or not. If one engine supplier is severly underperforming, it is impacting at least 2 teams. If the engine continues to be such a large performance contributor and differentiator, don't you see it to be just a little problematic given to what extend it is out of the teams ability to control it?
Moose wrote:Yet even with all of this, you still assert that it's all down to the engine.
It's funny that you say that in light of you quoting the excerp from my post that sais the exact opposite. #-o
So, again - it's not all the engine, that much is clear - but my post goes to great lengths to explain how engine performance can perhaps exaggerate what we may otherwise attribute down to a plain aero/chassis advantage. Do you honestly think that if you stick that Renault engine (assuming identical packaging requirements) into that Mercedes that it would still be significantly faster than the RedBull? I doubt it. What makes the Mercedes strong is the package - the sum of all pieces; aero, chassis and engine - the relevant question is what factor does the engine play in all this?
#Team44 supporter
Moose
Moose
52
giantfan10 wrote:MAO if you think costumer teams have the same engine output as mercedes... you cannot be that naive
Why would I need to be naïve to believe that? We've had customer teams for years. We've had customer teams (e.g. McLaren, RedBull) capable of beating the factory teams for years. The idea that the customer teams have something worse than Mercedes is just again - mean spirited and cruel under-acknowledgement of how good a job Merc's chassis engineers have done.
SectorOne
giantfan10 wrote:LMAO if you think costumer teams have the same engine output as mercedes... you cannot be that naive
What evidence do you have that says they don´t?
Does Sauber have less horsepower then Ferrari?
Does STR have less horsepower then Red Bull?
Just Mercedes right..?
Phil
66
Lets not get too sidetracked about what costumer teams are achieving to either proclaim the Mercedes power unit to be substantially ahead or not. Lets take a look at who those customer teams are:
In 2014
- Williams
- Force India
- McLaren
Williams struggled quite a bit the year before, so their budget was probably quite limited for 2014. In 2013 when engine performance was more or less equal and aero/chassis more important, Mercedes was good, Williams and Force India were way down in the midfield. So was McLaren too, who again in 2014 (and probably also due to the fact that they were leaving, so very limited inside to the power unit itself) struggled on the aero/chassis side. So while Mercedes clearly has the best chassis among the teams that run Mercedes power units, it's not exactly as if the customer teams are in the same league budget wise as their main rivals (Redbull + Ferrari + Mercedes).
#Team44 supporter
While i dislike the engine formula(understatement), the tokens... and everything else.
Red Bull's complaint is totally bogus.
Unfortunately for them they are stuck with Renault for the time being, and Renault is completely lost on how to improve their engine, but Ferrari kinda proved what you could do with limited tokens (i still dislike them and i think the complete freeze coming in a few years needs to be re-considered urgently), that one is not on the (stupid) rules.
Adding insult to injury they need to look in the mirror and see that their star driver burned his tires trying to chase down a rookie in a Sauber-Ferrari, their engine maker is lost and so is their new tech team.
TAG
What if... it's all a master plan by Renault to buy back into the sport through RBR at bargain basement pricing? 8)
माकडाच्या हाती कोलीत
Andres125sx
@Phil
Your argumentation about engines are not built by the team so the team can´t do anything to reduce the gap is right, but that´s how racing works. If we start that route, then we could say the same with any other part of the car
F1 teams don´t build batteries, they don´t refine their own fuel and looks like that is a huge factor wich harmed McLaren in 2014, they don´t build brakes either...
But they´re not forced to use any specific brand, they´re free to choose what they want, so if it´s not working as intended they have two options:
1- Push the supplier to improve their product
2- Change supplier
Basically all this moaning from RBR should be directed to Renault instead of FIA, and if they can´t improve it enough, then RBR is free to change engine manufacturer
If any manufacturer (Renault in this case) can´t compete with its rivals, that´s exactly the same as when HRT was unable to be competitive enough. Should FIA have helped HRT to be competitive enough freezing aero/chasis/engine development of his rivals? Obviously no.
Same for Cosworth in V8 era, they were not competitive enough so they ended up supplying teams like HRT or Virgin, but none of the top teams. Renault must do some homework if they don´t want to follow that route
FIA is not responsible if any manufacturer is not competitive enough, and teams cant (or shouldn´t) complain if one of their suppliers is not competitive enough. You decided to use that supplier, asume your responsability
giantfan10
giantfan10
27
Yes sauber has less horsepower than ferrari
red bull and Str no clue how renault handles that... red bull is not an engine manufacturer
SectorOne
giantfan10 wrote:Yes sauber has less horsepower than ferrari
Prove it.
FoxHound
55
Phil wrote:If the engine continues to be such a large performance contributor and differentiator, don't you see it to be just a little problematic given to what extend it is out of the teams ability to controll it?
The issue at large is that the engine needs to be a differentiator. Why should it not be? Aero has dominated for years, and greasy oily bits have had to take a back seat.
My overall impression of Red Bull is that they feel they have a divine right to win.
Renault is in the way of that, not the rules.
Renault will sort their problems, I have faith they will anyway. The only problem is that nobody knows when.
And this is motivating Red Bull to pressure the FIA into a change that suits them. Impatience allied to astonishing arrogance.
"Engines must be equalised" they proclaim. "That we may crush the opposition with our Aero prowess".
Hypocrisy.
What if Aero were to be equalised?
Then chassis?
Then drivers? :D
We could have a grid full of autobots driving identical cars. No favourites for anyone, pick a colour, any colour and root for that droid, man!
Equalisation is not part of F1 and never has been.
JET set
FoxHound
55
I think Red Bull has bombed F1tech with spam!! :lol:
JET set
Erm, there is a clear reason Ron Dennis is stating they want to have an OEM provider [Works team] because as a client, they are not able to beat Mercedes whilst having the 'same' engine.
http://www1.skysports.com/f1/news/12433 ... onda-power
williams is not having the same engine as AMG Mercedes. it may be 95% the same, perhaps even 98%, that's enough.
It would be naïve to assume Ferrari, Mercedes, whoever is willing to get beaten by competitors whom are clients of their very engines.
FoxHound
55
That is not proof Manoah.
It is common knowledge the Merc V6 in the McLaren used Mobil lubrication. This cost the team as it did not have access to Petronas lubricants.
Any suggestions that the engine is not the samerequires proof. The FIA have information on all the engines right down to infinitesimal minutiae.
And I've not heard a word regarding inequality.
Lets assume the hardware is the same until we can prove otherwise.
JET set
SectorOne
Manoah2u wrote: Erm, there is a clear reason Ron Dennis is stating they want to have an OEM provider [Works team] because as a client, they are not able to beat Mercedes whilst having the 'same' engine.
Worked brilliant for Ron previosly though.
Then you need to take into account Mclaren was frozen out by Mercedes because of Mclaren deciding to go with Honda.
That decision was made before a V6 Mercedes engine sat in a Mclaren car.
They made the annoncement in 2013 so naturally Mercedes had to protect themselves against Honda.
Manoah2u wrote:williams is not having the same engine as AMG Mercedes. it may be 95% the same, perhaps even 98%, that's enough.
So whats different? What are these components you speak of that makes up the last 3-5%?
Manoha2u wrote:It would be naïve to assume Ferrari, Mercedes, whoever is willing to get beaten by competitors whom are clients of their very engines.
you mean like when Mclaren used to wipe the floor with Mercedes for two whole years in the V8 days?
