[KVRC] Khamsin Virtual Racecar Challenge 2016
julien.decharentenay
Re: Khamsin Virtual Racecar Challenge 2016
CAEdevice wrote:
julien.decharentenay wrote:
CAEdevice wrote:The limit I have is that I am not able to extract the pressure differential and to write it in a log (as it happens with the areo forces).
Sorry about not having taken up on your earlier query on this. To extract the pressure differential, please do the following:
- Start ParaView;
- Open the openFoam file;
- Only select the boundary condition (in the part option) that you want to calculate the surface integral of pressure on;
- Apply a calculator filter;
- Set a new field "Pressure = 1.2 * p" (the pressure calculated and output by openFoam is normalised by the density);
- Apply the Surface Integral Filter;
- the surface integral of pressure is reported under Pressure.
Change the selected boundary condition to extract the value at the other surface.
CAEdevice wrote:Another issues for a beginner is the manage the double start (preliminary run). What about starting directly from the second stage?
You can, but it just takes longer to establish, hence more iterations...
I finally managed to find a way to calculate the integral of presisone with Paraview (thanks Julien ), however , there is something wrong with the post processing (it fails very often when generating the pictures): it would be useful to calculate the COP by hand (I do it approximating the drag resulting position) . What is the algorithm used by OCCFD ? Would it be possible to include the COP in a text report ad not only in the HTML report ?
This was part of my plan (to output the values in a text file rather than a CSV. There is a way to calculate the CoP manually, but I am reviewing it at the moment - MantiumRAY queried me and found a (likely) small bias in my calculation.
On the race #1 news, the CFD simulations are coming through. RicME is currently at the front of the pack - of currently five simulations, so it could change, and this result needs to be peer-reviewed by Chris. The resubmission deadline for non-compliance was pushed back to 6th May due to delay in compliance checking...
RicME85
52
Had the result email through :)
RicME85
52
cdsavage wrote:..
Chris, when you do the legality check for the front suspension, what position do you use for checking from the front?
Do you use the default front view in a specific program?
cdsavage
cdsavage
19
RicME85 wrote:
cdsavage wrote:..
I use an orthographic front view. In Paraview for example, you can do this using the "Use Parallel Projection" option in the settings.
RicME85
52
thankyou, just wanted to make sure was working off the same hymn sheet as I know different programs have different camera views
Chris should be sending the compliance email shortly (or has already done so). The resubmission deadline has been moved back to the 8th May to allow for a couple of days...
Alonso Fan
My car was illegal :mrgreen:
Minor issues which I would have an could have sorted out had I not been stuck for time. And Chris pointed out the hole in my car :)
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
CAEdevice
I have just received the results: I could have done a bit better (I noticed a small issue caused by the front suspension interaction with the flow around the diffuser when it was too late to find a solution) but I am happy because the official data are exactly the same of my local simulation. This is important (it was my biggest limit during 2015) because it makes the development more interesting.
graham.reeds
graham.reeds
16
Slightly OT.
This link came through earlier in the week but I forgot to post it.
https://youtu.be/j0IKIvZPtfE
It is a SimScale tutorial entitled Aerodynamics of Futuristic Car.
Note: I haven't watched it myself yet.
CAEdevice
graham.reeds wrote:Slightly OT.
I would like to see a demo with a KVRC car too :)
Alonso Fan
Seems to have gone a bit quiet
How are the simulations coming on Chris?
SHR Modding
Youtube
Twitter
Discord
cdsavage
cdsavage
19
Alonso Fan wrote:Seems to have gone a bit quiet
We're just waiting for the simulations for the resubmitted entries to finish. Hopefully everyone who was not asked to make another submission has received the compliance check email and the simulation results by now.
Alonso Fan
I've only received the compliance check email, but not the results
SHR Modding
Youtube
Twitter
Discord
HP-Racing
HP-Racing
We have only recieved the compliance information.
cdsavage
cdsavage
19
Ok, let me check what's happened with the first round of simulations, sounds like there's been a problem.
