Scuderia Ferrari SF16-H
aral
aral
26
Re: Scuderia Ferrari SF16-H
paddyf1 wrote:I dont think thats next years rear wing, its just for the purpose of the test !!??
whilst basically off topic, that is the 2015 wing on a 2015 car. but as the tyre offset is inwards, the end plates needed to be cranked to clear the tyres
holeindalip
holeindalip
But they have to simulate the down force levels of 2017 so it probably is wider to a degree
paddyf1
paddyf1
Its a lot wider than this years wing !!!
SR71
Pretty sure the Wing is wider. End plates likely connect at the exact same point as 2015 as changing them would be much more intense than what you suggest. The floor width was increased as well. Basically everything moved away from center line except the suspension/brakes/wing end plate mount points.
Way to costly to modify those structures for a test like this.
poolboy67
all of those little changes were made just to get the car to as close to as possible of the 2017 rules, but because of obvious reasons, ferrari can't make a 2017 spec car and do testing with it, yet. so they've just modified it to sort of represent the sort of downforce that the cars will have next year.
the rw is just wider, but not lower (as they're going to be) because the aerodynamics of this car is basicly designed for a high rw. they would also have to make a new floor, to fit a 2017 spec wing.
there are skirts to generate more ground effect, because the diffusors are bigger next year. and i bet ferrari didn't want to, or wasn't allowed to make a new diffusor or a floor, to 2017 spec.
if they would've slapped on 2017 spec wings and floor, the rest of the aerodynamics would've needed redesigning.
what they did now, was they used tricks to get more downforce and ground effect, by just adding aero bits on the original car, to simulate 2017 specs.
this was a 'cheap' and functional way to test the tires, because they can collect relative data that can be comparable.
paddyf1
paddyf1
holeindalip
holeindalip
I think this confirms the rear wing is much larger
paddyf1
paddyf1
So what does everyone think of next years tyres ??? me i think they look good !!!
FW17
168
Why are they using skirts? :lol:
Rear wing as wide as can be - more or less !! ?? !!
Juzh
161
FW17 wrote:Why are they using skirts? :lol:
To seal the edges and generate more downforce?
Can we stop discussing 2015 Cars, 2017 Cars and 2017 Tires in the 2016 Ferrari Thread? :roll:
There is a Thread for 2015 Cars Testing 2017 Tires:
http://www.f1technical.net/forum/viewto ... =1&t=24264
There is a Thread for 2017 Cars:
http://www.f1technical.net/forum/viewto ... &start=435
There is a Thread for 2017 Tires:
http://www.f1technical.net/forum/viewto ... &start=105
Nothing of that has anything to do with the SF16-H
paddyf1
paddyf1
To simulate 2017 downforce levels !!
FW17
168
Did not read the rules as it had changed so many times
What is the final height of the diffuser? 175 mm? (currently 125)
They could have just used the 2013 floor.
