From Wikipedia:SameSame wrote:I'm sorry I'm busy using my phone but I'll show you later a proper derivation using a computer.
Please do some reading on how a gearbox works. Just google is power conserved between gears and you will see thousands of links confirming that.
Energy has no units of seconds in it.
I'll say it one last time. Power is constant through gears and torque is what changes. Without any spinning motion of the gears no torque is transmitted and therefore the conservation of energy is not violated. As soon as the gears move POWER is transferred between gears and therefore ENERGY IS CONSERVED as you just have to multiply the power by time to get the energy.
In angular mechanics, torque is analogous to the linear Newtonian mechanics parameter of force, moment of inertia to mass, and angle to distance. Energy is the same in both systems. Thus, although the joule has the same dimensions as the newton-metre (1 J = 1 N·m = 1 kg·m2·s−2), these units are not interchangeable: the CGPM has given the unit of energy the name "joule", but has not given the unit of torque any special name, hence the unit of torque is known as the newton-metre (N·m) - a compound name derived from its constituent parts.[5] Torque and energy are related to each other using the equationSameSame wrote:That is literally what I have been saying for the past hundred posts… (1 J = 1 N.m)
And I've been told the units don't check out…
SameSame wrote:I never said they were interchangeable…
In power, N.m is converted to J for convinience sake…
I was also told a radian is not dimensionless…
My point was that N.m/s is expressed as J/s. Look how power is derived.
Edit: All I wanted to convey was that 1 J = 1 N.m. Not the technicality of whether they can be used interchangeably. I was told the units don't work out and how can a gearbox work if that is true.
torque and energy have the same units, but since you explicitly stated that torque = energy I think it is not far fetched to think that you want to use torque and energy interchangeable.SameSame wrote:Indeed I am. Think about power. rad/s (angular velocity) x N.m (Torque) = J/s. (A radian is dimensionless)Cold Fussion wrote:Are you saying torque is energy?SameSame wrote: Torque is N.m an not N/m… and N.m = J so power is basically the rate at which the torque is delivered, which is perfectly in line with what FoxHound said.
Last point because this is way off topic.rscsr wrote:SameSame wrote:I never said they were interchangeable…
Edit: All I wanted to convey was that 1 J = 1 N.m. Not the technicality of whether they can be used interchangeably. I was told the units don't work out and how can a gearbox work if that is true.torque and energy have the same units, but since you explicitly stated that torque = energy I think it is not far fetched to think that you want to use torque and energy interchangeable.SameSame wrote:Indeed I am. Think about power. rad/s (angular velocity) x N.m (Torque) = J/s. (A radian is dimensionless)Cold Fussion wrote:
Torque is a meaningless quantity when considering the performance of a vehicle. When the manufacturer specifies torque, this torque is measured at the flywheel. After the flywheel, the drive train has a gearbox which changes the torque at the output relative to the input (by conserving energy and not torque). Why is this important? Because once you know energy is conserved throughout the drivetrain (and thus power), and you know that Power = Torque x Angular velocity, you can see what is of most importance is power and not measured flywheel torque.FoxHound wrote:http://s2.quickmeme.com/img/b3/b3d65e69 ... d7a5c2.jpg
I'm reading that horsepower is a (nigh on)fictitious measurement designed to give an apt description to prospective buyers as to the indication of the power.
James Watt responsible.
Torque is measurable, and a complete indicator of the rotational force.
So why would it not be plausible that a 150bhp 200nm Diesel of same mass and size to that of a 170bhp 120nm Petrol, would be quicker.
It has more rotational force, and the as Horspeower is defined from inception as thus:
http://www.hemmings.com/magazine/hmn/20 ... 18941.htmlTo get industries to begin adopting his steam engines, Watt came up with the term horsepower so buyers could have a way of comparing his engines with more traditional power sources. One version of how Watt first calculated the meaning of horsepower starts with an early customer, a saw mill that replaced horses with a steam engine. The horses were attached to a 24-foot diameter wheel, which yields to a circumference of 75.4 feet around. Watt determined each horse's pulling force and came up with an average of 180 pounds per animal. He counted that the horses turned the wheel 144 times per hour, which is 2.4 times per minute. With a 75.4-foot path around the wheel, each horse was moving 181 feet per minute. Multiply the feet per minute (181) by the force of each horse (180) and you arrive at 32,580. Watt did the same and rounded up to an even 33,000-lbs.ft. per minute to determine the value of one, single horsepower.
It suggests that Horsepower was designed to give indication of the power available over a timed period, in the above a minute being the timed period.
So to my mind, and without the math, it suggest exactly what the Yuasa engineer was purporting over a cold one.
The petrol can deliver it's torque quicker, but it's torque, or rotational force, is circa 40% down on the Diesel, which in turn is circa 15% down in terms of horspower.
Cold Fussion wrote:Bhall It's happening again.
Very interesting how quickly your tune has changed? So all of a sudden a gearbox does conserve energy?Cold Fussion wrote:But it just doesn't check out at all. If torque is energy, how would one apply the conservation of energy in a gearbox? I have a torque at the input shaft and a different torque at the output shaft, if torque is energy, then where did this extra come from? Perhaps the teapot floating around Venus put it there? Similarly, if radians are a dimensionless unit, then why don't we measure angular velocity in hertz? You contend that radians are a dimensionless unit but that isn't really correct.SameSame wrote:Hahaha that's pretty good. But the units check out. Not intuitive but yet still true.
Have you ever heard of gearing? And perhaps that any bhp figure is only at a particular point of a wide rev-range? To determine which car is actually quicker, depends on the gearing and how much power is available at that particular rev-range...FoxHound wrote:So why would it not be plausible that a 150bhp 200nm Diesel of same mass and size to that of a 170bhp 120nm Petrol, would be quicker.
When did I ever say otherwise?SameSame wrote: Very interesting how quickly your tune has changed? So all of a sudden a gearbox does conserve energy?
I quite clearly state that conservation of energy applies in a gearbox. If torque is energy and energy is conserved, and there's a difference of torque between input and output, how do you rationalise that energy (which for you is torque) is conserved?Cold Fussion wrote: But it just doesn't check out at all. If torque is energy, how would one apply the conservation of energy in a gearbox?
A shaft can be in static equilibrium under loadcase of 2 equal and opposing 100Nm torques. The torque in the shaft is 100Nm, the energy in this shaft is ZERO. Therefore torque =/= energy.SameSame wrote:Indeed I am. Think about power. rad/s (angular velocity) x N.m (Torque) = J/s. (A radian is dimensionless)Cold Fussion wrote:Are you saying torque is energy?
