Mercedes AMG F1 W08 EQ Power +
Re: Mercedes AMG F1 W08 EQ Power +
WaikeCU
Just noticed they aren't running the new nose with the vents. Signs of updates not working as supposed to?
aral
aral
26
Once again a number of off topic posts have been removed. If you want to discuss the race, Ferrari, Allison etc, please do so on the appropriate threads.
F1Krof
94
WaikeCU wrote:
30 Apr 2017, 15:28
What new nose? [before]
Ahh, I don't think the vents were for performance. I believe open vents are for driver and some hydraulic cooling, those kind of vents actually reduce performance (downforce).
Wroom wroom
Radley
Radley
They didn't run the open chimney on top of the shark fin either
adrianjordan
Radley wrote:
30 Apr 2017, 22:38
Do you think this could have contributed to Hamilton's overheating problem?
Favourite team: McLaren
ScrewCaptain27
577
From the F1 Facebook page:
- Serj Tankian
Caerdroia
Caerdroia
Sky reporting that part of the reason that Mercedes have been running 6kg overweight is because they had to revert the gearbox pre-season to a heavier version. Anybody heard any more details as to why?
The Mercedes as raced in the first four races is 6kg overweight - partly as a consequence of the original gearbox having to be replaced pre-season by a heavier unit.
A reconfigured version of the original lighter gearbox is set to be part of the Barcelona upgrade, along with suspension changes front and rear and a general weight-saving programme that should allow the team to revert to being able to use ballast to vary the weight distribution from track to track.
http://www.skysports.com/f1/news/12433/ ... is-concept
dans79
267
Caerdroia wrote:
08 May 2017, 10:03
This could be a big step for them, as they will be able to run lighter, and use ballast to better balance the car. They will have to hope that practice is clean so they can get enough laps in to get a good baseline setting.
197 104 103 7
mmred
mmred
-3
dans79 wrote:
08 May 2017, 16:28
Caerdroia wrote:
08 May 2017, 10:03
it would be interesting to know how much in terms of tenths u can gain from a noballast situation to say a 5kg ballast situation and also how many more laps they can flatten the tire performance window
then if u can add the effect of 5kg of overwight suppressed u could have a performance gain before the car is on track
would it be too much to think an overall esteem would be around3 tenths max 1 min( and i think in a so close competition the max would be an huge improvement )
any info on this?
According to reports they have no free ballast now. So a 5kg ballast situation means the car will need to be 10kg lighter than it is now if they are 5kg overweight now.
Any reports on the cause lewis' overheating problems in Sochi? Even in free air the temps were critical and it was not said which components were overheating.
mmred
mmred
-3
PlatinumZealot wrote:
09 May 2017, 06:17
thanks
so they reduced the weight of 5/6kg, that surely is a pure performance gain
BrunoH
BrunoH
i dont believe they can cut 10 kilos.... maybe the 5... and its a big cut already for an F1 car. unless they are using less batteries... and thats not going to happen...
dans79
267
BrunoH wrote:
09 May 2017, 13:45
You need to remember that they had a lighter transmission during pre-season testing but had to revert to an older heavier design (what they are using now), so I would say 10 is in the realm of possibility. However it will all come down to how radical the changes they are making are.
197 104 103 7
