Williams FW40 Mercedes
LookBackTime
LookBackTime
472
Re: Williams FW40 Mercedes
LookBackTime
LookBackTime
472
Williams to trial "significant" car changes in Hungary test
By: Adam Cooper, F1 Reporter
Williams is planning to test some "significant" changes to its Formula 1 car during this week's post-Hungarian Grand Prix test, as part of new concept analysis to turn around its fortunes.
The Grove-based outfit is currently fifth in the constructors' championship standings, but knows it needs to lift it game to ensure it can stay ahead of Toro Rosso, Haas and Renault.
With technical chief Paddy Lowe seeing areas for improvement since joining the outfit at the start of this year, sources have suggested that key areas of the car's philosophy will be evaluated with new parts this week.
Although Lowe has drawn short of calling the major changes – believed to be both aerodynamic and mechanical – a B-spec version of the car, he has confirmed the changes are important for working out what his team needs to do.
"There are some fairly significant bits that we're trying," said Lowe. "We're doing some interesting bits of R&D. Some are relevant for this year, but some are things we need to learn and understand for next year. There's some important work going on, actually.
"It's a set of experiments, that's the best way to put it, which is how we always conduct our testing. Where that leaves us in terms of what we take racing is a downstream consideration."
The Williams work comes after a disappointing weekend in Hungary, where it failed to score any points.
Even before Felipe Massa's illness threw a spanner in the works, it was clear that the team was not be competitive on the tight and twisty Budapest track.
Lowe said he hoped the difficulties would act as a spur for a bigger effort to turn things around.
"I just said to the guys that's a good weekend to motivate us to make a quicker car," said Lowe. "I think that's the best way to sum it up – we've got a lot of work to do, and we need to be better than that. And we can be better that. So that's what we'll go away and do.
"There's a pretty clear pattern, we're not performing as we should at what you would call the max downforce circuits, so those are Monaco, Hungary and Singapore. But I'm never one to give up before we've got there, so we'll see what we can do for Singapore. A lot of it is about fundamental design aspects that we'll have to wait for another year."
Lowe stressed that the team hasn't yet ruled out chasing Force India for fourth place in the world championship, despite a significant gap having opened up.
"We wouldn't give up on that. I think we can be very strong at some other races this year. Hopefully some of the ones coming up. And we'll aim to get better at exploiting the performance with points, which we've also not been great at doing in the first half.
"The first half term report is could do better – could do a lot better – and we'll go back to the second half with that mentality."
Lance Stroll has been drafted in to this week's Hungary test with Massa being forced to step down because of his illness.
https://www.motorsport.com/f1/news/will ... st-937258/
atheonr
atheonr
Rear suspension looks a little bit different
LookBackTime
LookBackTime
472
Not many pictures!
LookBackTime
LookBackTime
472
High resolution
atheonr
atheonr
These are the differences i could find on the car
LookBackTime
LookBackTime
472
FW is very close to the track. Illusion ?
Kerbs.
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
@ScarbsTech made this info public:
"My info is a carbon outer gearbox case, but I can't see it from photos today."
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
Test Hungaroring: la Williams prova il nuovo cambio in carbonio!
https://it.motorsport.com/f1/news/test- ... io-937611/
Google translate:
Hungaroring test: Williams is testing the new carbon gearbox!
The FW40 has a fairly new rear: in addition to the transmission in composite materials there is also a different rear suspension. The goal is to find that mechanical grip that is always missing in the slopes where it is very loaded.
After Silverstone there was a tough verbal confrontation between Lawrence Stroll and Paddy Lowe, Williams technical director. Lance's dad, grove sponsor of the Grove team, had complained of the inadequate competitiveness of the FW40, which in the last races has made an incredible jump back since the introduction of the new aerodynamic package that did not seem to have worked according to expectations.
The Englishman did not repudiate the allegations claiming that Williams is working hard to make a break in the season and that the effects of the job will be seen in the recovery of GPs after the summer break. Paddy Lowe knew that it would be ready for the Hungaroring tests for the first composite material box to accompany a new rear suspension.
In fact, the former Mercedes technician has imposed a carbon double-breasted Carbon Transmission as it has been in Brackley for years so that it can make changes to suspensions without having to replace the gear that has to be six GP. This achievement makes it possible to have a much stiffer rear wheel that should finally allow Williams to find that aerodynamic load in the rear that has always missed it in recent years for the box flexions that were particularly miniaturized to favor aerodynamics, but Against it did not have a great stiffness that affected the lack of mechanical grip that was felt especially in the slow mid slopes.
Lance Stroll yesterday and Luca Ghiotto today have the task of appreciating this solution that allows to use a more modern rear suspension as a pull rod pattern, in line with what the top teams did.
LookBackTime
LookBackTime
472
High resolution
atheonr
atheonr
Rear with flowwiz
LookBackTime
LookBackTime
472
