Toro Rosso STR13 Speculation Thread
mrluke
mrluke
Re: Toro Rosso STR13 Speculation Thread
ScrewCaptain27 wrote:
22 Feb 2018, 00:13
HPD wrote:
21 Feb 2018, 14:47
https://twitter.com/ToroRosso/status/966280959099396096
Journalists also see a predominant white color :?:
It stutters on upshifts just like last year’s McLaren. NOT a good sign, implying Honda STILL have not solved their vibration issues.
Mercedes have the same noise on upshifts, I don't think it's something you can completely avoid just minimise its impact.
Singabule
Singabule
mrluke wrote:
22 Feb 2018, 02:01
22 Feb 2018, 00:13
HPD wrote:
21 Feb 2018, 14:47
Depend on how aggressive the shifting set up, it cost merc transmission failure in 2016. I think this brand New colaboration need few things to be solved together, so they try as aggressive as possible so that they could pick up starting point. Not sure about the aero, but i think in first test we would see brand New wing and bargeboard. The livery of Last year car already stunning, no need to change it
Flying JPS Lotus
37
Looks more like the old STR10 nose with the hole you seen in the center of the STR13's nosecone.
"Looks like meat's back on the menu boys!"
#AeroUruk-Hai
iichel
iichel
yeah but MCL32 nose had honda on it :D
The MCL32 nose looks more a straight line with a clear kink at the top of the monocoque while the STR10 has a gradual curve. But looks like a slot at the tip.
Flying JPS Lotus wrote:
22 Feb 2018, 08:48
https://cdn-4.motorsport.com/static/img ... -str10.jpg
whoa, even the airbox looks the same
restless
restless
Given rumours that TR is "1 month behind the schedule" posted in the forum.
Maybe they decided to run 2017 car (just fixed for regulations) during barcelona tests - to have pure comparison between Honda&Renault engines and reevaluate/confirm aero simulations
Working to bring "real" 2018 chassis for Melbourne
Does that make sense?
what year car can they freely test? if so, the STR10 testing would make sense;
they have ALL the data on the original STR10.
they have all the data on the 2017 STR - regarding fat tires, wings, etc.
have somebody simulate and work out the data in mounting 2017+ spec material on a STR10.
and have somebody work out a way to plant the honda engine in there.
use it as a testbed for testing the honda engine.
keep developing and testing the STR13 untill the last moment possible, melbourne.
possible?
NathanOlder
They cant test a current engine though can they ?
GoLandoGo
Lewis v2.0
King George has arrived.
the EDGE
the EDGE
67
Manoah2u wrote:
22 Feb 2018, 09:56
22 Feb 2018, 08:48
u think? 13 looks wider & flatter to me
Sigh. The Honda blame has already begun and they havent even tested yet! And you have a Mercrdes breaking down after a short distance and no one bats an eyelid.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
restless
restless
PlatinumZealot wrote:
22 Feb 2018, 14:09
What do you mean ?!
SparkyAMG
restless wrote:
22 Feb 2018, 16:46
22 Feb 2018, 14:09
What do you mean ?!
The W09 stopped when it first left the garage. Bottas was pushed back in and was on his way shortly afterwards.
cplchanb
cplchanb
SparkyAMG wrote:
22 Feb 2018, 16:57
restless wrote:
22 Feb 2018, 16:46
22 Feb 2018, 14:09
What do you mean ?!
Probably tripped a sensor or something really minor...nothing big to report
Flying JPS Lotus
37
the EDGE wrote:
22 Feb 2018, 12:28
Manoah2u wrote:
22 Feb 2018, 09:56
22 Feb 2018, 08:48
I mean obviously the exact design has changed a little from 3 years ago but the idea stays the same. Their new nose seems an obvious iteration of those they've used in the past like on the STR10 & 11 before dropping it for a Merc style nose on the 12.
#AeroUruk-Hai
ScrewCaptain27
577
Manoah2u wrote:
22 Feb 2018, 12:14
possible?
It makes absolutely zero sense. The car in the photos is a clear evolution of the STR12.
- Serj Tankian
