nosles on engines i do not understand
pompelmo
pompelmo
can anybody tell me what are these nosels good for....
manchild
manchild
Tp
Tp
But why's it all exposed like that?
manchild
manchild
Such position enables better filling of intake channels and reduces the turbulence of air going from snorkel into trumpets. If they would be fixed sideways or similar to his position but deep inside it would cause reduction of intake channel diameter, worse atomisation of fuel and worse mixing with air.
zac510
zac510
22
Actually it would be more fuel efficient if they placed the injectors in the ports, but power takes priority here.
DaveKillens
DaveKillens
34
The injectors are very high pressure, and when opened, spray out a very fine mist. The idea is to break down the gas droplets into as small pieces as possible, to give better fuel burn. Being so far from the combustion chamber, this gives the air fuel mixture more time and chance to evenly disperse into a very, very fine homogenous mist before it enters the combustion chamber. Remember, a large droplet of fuel won't burn properly, you want a complete, controlled burn with the gas droplets as small and evenly dispersed as possible.
zac510
zac510
22
Also isn't it regulation that the injectors cannot be in the port?
DaveKillens
DaveKillens
34
FIA technical regulation 5.7 Fuel systems
5.7.2 Only one fuel injector per cylinder is permitted which must inject directly into the side or top of the inlet port.
Tp
Tp
Watching the video, what's with all the vapour? Surely at the end of the race the engine cover inside will be covered with fuel
DaveKillens
DaveKillens
34
No way, a lot of air is sucked through those trumpets, and all the fuel goes into combustion. Even at an average of 15,000 RPM, the engine sucks in 18,000 liters of air each minute.
Sodder
Sodder
A little off topic but which track are they running on their computer test program?
All I know is I don't know much....
http://batracer.com/-1FrontPage.htm?6l
NickT
The fuel also vapourises which cools everything down, increasing the density of the inlet charge (fuel air mix) and contributes to greater power.
The mist is caused by the pressure drop around the inlet trumpet, rather like that seen over the upper side of a fighter plane wing during a high G turn.
NickT
manchild
manchild
Sodder wrote:A little off topic but which track are they running on their computer test program?
Monza
Sodder
Sodder
Thats what I thought. Thanks!
manchild
manchild
Chek this one :arrow: http://video.google.com/videoplay?docid ... 9926133763 very 8)
Its one of the RS series from 90s but sight and sound is soo good :wink:
