McLaren MCL35М Speculation Thread
charliesmithhd
67
Re: McLaren MCL35М Speculation Thread
FittingMechanics wrote:
03 Feb 2021, 22:23
Can't figure out what is that.
engine cover
haza
haza
wowgr8
wowgr8
29
That's the 2020 car engine cover, look at the picture of the MCL35 and turn this picture around you'll see if fits perfectly, the shape as well as the colours
charliesmithhd
67
wowgr8 wrote:
04 Feb 2021, 11:39
its not, the livery is different
Niiek
Niiek
Craig Scarborough mentioned it on his Twitter, definitely bulkier at the top compared to the 2020 car.
_cerber1
239
the air intake is smaller?
f1rules
f1rules
581
the sidepod wings wavy?
charliesmithhd
67
f1rules wrote:
04 Feb 2021, 14:37
https://pbs.twimg.com/media/EtYfjNVXIAMSW2N.png
mcl35 had wavy wing (seen in the shadow) not sure if its the same profile though
charliesmithhd
67
airbox looks slightly different, missing the curved element. (unless camera hasn't picked it up)
Yeah, now it's a mix between the Merc style airbox and the 2020 Mcl airbox.
It seems they modifed the vertical crash structure.
jjn9128
769
Blackout wrote:
04 Feb 2021, 15:12
https://i.imgur.com/MOjrHfg.jpg
Not got the rule book to hand but can they alter the roll hoop? Using their tokens to modify the back of the safety cell to accommodate the merc pu.
More likely they modified the carbon around it.
#aerogandalf
the EDGE
the EDGE
67
jjn9128 wrote:
04 Feb 2021, 15:22
Blackout wrote:
04 Feb 2021, 15:12
The simple answer is No, all crash structures are homologated, but McLaren aren’t restricted by the token system. They can make any amendments necessary to fit the new PU as long as the FIA agree they are necessary, and not done for a performance benefit
These changes will be extensive given the different architecture of the 2 PUs, you simply can’t replace 1 with another without changing everything connected to it, or positioned around it
None of that means there will be any advantage gained or lost, simply it is different from before
f1rules
f1rules
581
looks almost 1/1 copy of the merc
jjn9128
769
the EDGE wrote:
04 Feb 2021, 15:28
jjn9128 wrote:
04 Feb 2021, 15:22
Blackout wrote:
04 Feb 2021, 15:12
It's a bit of a mockery of the standard engine mounting points when you have to make changes for oil tanks and such
#aerogandalf
v3rify
v3rify
blurry frame of the rear of the car, not sure if anyone can make out anything significant from this. Image
