hello does anyone know the dimensions of the connecting rod of the tj v10 engine length, width diameter of the connecting rod head and connecting rod foot and depth of the bores and shapes machined in the connecting rod as the width and diameter of the connecting rod bearings.
The width of the little end is 14.96 mm.
The width of the big end is 19.14 mm.
The depth of the pocket machined into the side of the rod is 5.07 mm.
The diameter of the little end is 17.68 mm.
The diameter of the big end is 38.15 mm.
thank you very much, would you happen to know the diameter and thickness of the connecting rod bearings and the diameter of the connecting rod journal and the crankshaft journal?
Unfortunately my conrod doesn't have any big-end bearings.
I don't have a gudgeon pin either sorry but I imagine it'd be between 0.001" to 0.0005" smaller than the little end bearing diameter.
The main body of the rod is 14 mm thick.
you could take the scanner of the printer to print documents and scan the piece to real size to get the template and then I will take care of putting the dimensions and dimensions.
