Scuderia AlphaTauri AT03 Speculation Thread
MrGapes
31
Re: McLaren MCL36
FittingMechanics wrote:
14 Feb 2022, 13:28
MrGapes wrote:
14 Feb 2022, 12:54
As far as I know, Franz Tost confirmed in a article that they will be using redbull rear suspension, gearbox, and he said they may use parts of the front suspension or the whole thing. Anyway I don't expect them to design there own, they've been quite reliant on redbull for the past few years,
AT seems to have standard suspension (pull rod front, push rod back).
yep seems like it, rear pull rod seems to come pretty far forward compared to what we have seen so far
but I don't trust renders, I'd rather see a real car, so maybe we will see in a few days
ME4ME
79
Re: Scuderia AlphaTauri AT03 Speculation Thread
Sevach wrote:
14 Feb 2022, 13:25
Only nose thus far that extends past the wing, i'm thinking fake.
Plenty of work to do so they might've taken a strategic short-cut and made life easy for themself crash-test wise.
wogx wrote:
12 Feb 2022, 23:28
This is a show peice looking back on it.. One single panel for the entire left side of the car... Hehe.
We won't see the real care till the shakedown it looks like.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
MrGapes
31
https://scuderia.alphatauri.com/en/at03/
check out this website you can 360 around the 3D model of the car + website comfirms red bull rear suspension and gearbox
A good way to attract air and accelerate it towards diffuser top and beam wing
f1rules
f1rules
581
Very interesting for sure with these different aero concepts, this one starts out as the amr solution but instead of leading the air around/under the sidepods to the diffuser center, they seem to lead it for the diffuser edge to help seal i would guess, and then, like in the old times, guide the air from top of the sidepod down via a big ramp, very interesting i have to say
JRodrigues
JRodrigues
Huge undercut at the front
Pany
Pany
Not clear to understand, the air flux inside the lateral sidepod, where it goes? maybe there is hole
down back in the floor and goes in the diffure exit? I think is forbiddens, so where it goes?
f1rules wrote:
14 Feb 2022, 13:44
ajprice
ajprice
21
AeroDynamic wrote:
14 Feb 2022, 13:29
Rear and diffuser Brightened
https://i.imgur.com/V6hQNPQ.jpg
https://i.imgur.com/m5WEXVI.png
Their heat outlet looks like it's straight onto the beam wing. McLaren's looks higher above the beam wing and Aston outlets through the louvres.
AeroDynamic
349
JRodrigues wrote:
14 Feb 2022, 13:50
https://pbs.twimg.com/media/FLjZuCaXoAIDak8.jpg
Brightened +
AeroDynamic wrote:
14 Feb 2022, 13:29
That looks like holes in the roof of the diffuser presumably to feed air in. I assume it's an artefact rather than holes in the roof of the diffuser, however.
AeroDynamic
349
AeroDynamic
349
And extremely high driveshaft and rear bottom wishbones :!: They are very close to the top ones...
jjn9128
770
Blackout wrote:
14 Feb 2022, 14:01
The drive shaft to gearbox location is fixed within +/- 10mm from the bottom of the car (250-260mm).
Likewise the wishbones cannot join the upright lower than 40mm below the wheel centre axis.
#aerogandalf
