What is this thing on the wheel?
chapmanlung
chapmanlung
whats the thing sticking out of the wheel??
http://www.itv-f1.com/ImageLibrary/41782_2.jpg
tomislavp4
Not a clue :shock:
Have better angle?
nae
nae
i assume some for of wheel to wheel defence, but am prepared to be wrong
FW 21
FW 21
nae wrote:i assume some for of wheel to wheel defence, but am prepared to be wrong
I agree.
MrT
MrT
They are data aquisition sensors - Optical slip angle sensors.
jddh1
MrT wrote:They are data aquisition sensors - Optical slip angle sensors.
That's correct. You only see them in testing though as they mount on the wheel nut and it's not practical to have them on race weekends as you need quick tire changes then. That, and also you would not really focus on data collection while a race is underway, as well as not forgetting safety issues with these things flying off on contact.
zac510
zac510
22
It's a (or 4) Kistler wheel load sensor.
I'm not sure that it directly measures the slip angle but they may be able to use the force data to back-calculate the slip angle.
The optical slip angle sensors you are thinking of are probably the Correvit brand units.
Carlos
Carlos
You might enjoy Goggling the search term "Intelligent Tire" - quite a hot topic - I liked The Apollo - second site down - computer/sensor system testing - an extensive article pdf with a lot of technical detail. Measures slip angles, all sorts of variables, all sorts of applications, too many graphs to mention.
@Chapmanlung- isn't the tech term "A Thingie?" :wink: Good to have you on the Forum - most definitely.
Welcome Jddh1 - Well Met.
manchild
manchild
That's correct.
Not correct:
Renault F1 Team blog admin wrote:It's called a wheel force transducer. We used them last year too at certain points, used to measure energies on the individual wheels.
http://blog.renaultf1.com/index.php?en/ ... -07#c37737
jddh1
manchild wrote: Not correct
Oops, I stand corrected.
Also, thanks for the welcome. I joined a few months back, but I visit the site daily now.
MrT
MrT
Yep, sorry for that.
scarbs
scarbs
393
They are indeed wheel force transducers calle dKistler Road dyn, see this link http://www.kistler.com/do.productfinder ... =App.9280A
Many teams use them for tyre testing.
Scarbs
nae
nae
i stand corrected
but in a nice informative way
cheers
