Ferrari Technical Detail
modbaraban
modbaraban
Also seems like the grills right behind the T-wing are new... or not?
siskue2005
70
yup thats knew :)
I think it reduces the boundary line formation in those edges.....there by reducing Drag
And also reduces the movement in Cross winds also :)
TERRASTAR18
TERRASTAR18
PNSD wrote:i thought VG's at first.
what does vg mean?
RH1300S
RH1300S
what does vg mean?
Virtual Golf
Carbon
Carbon
...Vortex Generator?
modbaraban
modbaraban
...Vegetable Grinder? :shock:
FLC
FLC
Actually those grills are not new. They are there since Magny-Cours, I think they added them when they made those aero changes during the silverstone test:
[IMG:739:513]http://img454.imageshack.us/img454/8862 ... llsgk0.jpg[/img]
I dont think anybody mentioned it, but the size of the revised sidepod shields on the F2007 is now pretty huge, definitely bigger than before and the shape is a little different too, a bit BMW like:
[IMG:547:489]http://img160.imageshack.us/img160/7741/image1yn0.jpg[/img]
Do you think they might have problems directing the air to the rear wing or maybe it's supposed to work better with this rear wing configuration? They were obviously having problems with the low downforce configuration in north america, maybe these upgrades are meant to deal with that...
Saribro
Saribro
Those grills were there at least since Spain:
Though as you can see, back then that area was painted red, now it's plain black.
siskue2005
70
FLC wrote:Actually those grills are not new. They are there since Magny-Cours, I think they added them when they made those aero changes during the silverstone test:
We where actually talking about the grils on the T-wing ( chicken wing? )
The grills you are talking about are present there since the start of the season :)
siskue2005
70
Saribro wrote:Those grills were there at least since Spain:
is there any reason , they are painting the whole part Black???
any exhaust heating problems??...is it melting down the paint??
Maybe :?
modbaraban
modbaraban
siskue2005 wrote:The grills you are talking about are present there since the start of the season :)
Nope the grills layout changed a number of times... And I was talking about those (black) grill in this case. :wink: I though they changed em to coordinate the aero behind the new cut-T-wings and cut-Flaps :wink:
mx_tifoso
mx_tifoso
The number of "gills" changes accordingly with the aero setup, as well as with the climate where they will be used. Early on during the season we saw a lot more "gills", I believe there was a maximum of fifteen on each side at one point.
I haven't counted the total number of "gills" during the Spa test, but I didn't notice a significant amount of "gills" less than in previous GP's. Why would you have the same/similar cooling configuration in cooler conditions, such as rainy Spa-Franchorchamps, as Spain or similar climate GP's?
And I would imagine that the area surrounding the exhaust tip is left uncolored because the paint would melt, or be damaged by the hot expelled "fumes".
You can also note from the last two photos that the length of the exhaust varies as well
What a beautiful car though!
siskue2005
70
mx_tifosi wrote: And I would imagine that the area surrounding the exhaust tip is left uncolored because the paint would melt, or be damaged by the hot expelled "fumes".
yup i noticed that.....in Monaco it was a small exhaust....now its bigger
good looking car.... 8)
Birel99
can someone please explain the effect of the power band by having a longer vs short exhaust?
and what about the circumfrence of the exhaust tips???
THanks,
Carlos
Carlos
@Birel99
These links will offer insight into intake and exhaust lengths and should answer your question. Your question may be a little off topic (ie. Ferrari Technical Detail) ... perhaps check the Forum Index for a thread on the subject or introduce a new thread topic. Glad to be of help.
http://pweb.jps.net/~snowbum/InExTuning.htm
http://www.challengers101.com/IntakeTuning.html
http://www.team-integra.net/sections/ar ... icleID=466
http://www.mne.psu.edu/me415/fall05/SAE/intake.html
http://www.jrbranson.com/hondaracer/hon ... design.htm
http://www.nightrider.com/biketech/calc ... length.htm
http://www.torquecars.com/tuning/sports-exhausts.php
These links deal with length, diameter, volume and wave action for intake and exhaust tract design and tuning.
