Ferrari Technical Detail
megz
O, Sneaky!
rkn
What does the sidepod fins do anyway, and how do the slits help?
modbaraban
modbaraban
rkn wrote:What does the sidepod fins do anyway, and how do the slits help?
As far as I know, just as most of the latest developments by F1 teams the sidepod vanes are used to direct/shape the airflow in order to help other parts either generate more downforce or decrease drag or improve cooling.
mini696
The shields direct air into the radiators at low speeds.
The slots relieve (bleeds) the pressure that backs up in front of the radiator at high speeds... They give the air somewhere to escape to.
Zack
Ferrari F2007 front wing detail
what are those values? or presets?
PNSD
PNSD
they are values so they can adjust the front wing... i assume they are the angle of attack, not sure though..
modbaraban
modbaraban
Zack wrote:Image
This is the rare opportunity to see clicks :lol:
megz
What an awesome picture :)
kimi
kimi
i believe these are the various front wing angles that the teams change in order to find the optimum set-up.even under changeable weather conditions it helps setting the right wing angle to get the desired down force.
great pic though. :)
Scuderia_Russ
Probably measured in degrees from a pre set base line. ...Scarbs?
"Whether you think you can or can't, either way you are right."
-Henry Ford-
