Mosley said:
"We've finally found a serious engineering challenge for the teams in KERS. Some manufacturers have risen to this challenge, one manufacturer has produced electric systems which will astonish people when they appear,
another team is working on a completely new technology which will also astonish people."
Completely new technology? Any ideas?
Back on thread:
"I think the teams will soon learn how to use and optimise KERS, but it won't help overtaking so much. It's a technology developed on road cars that will find a limited application in F1. The new aerodynamics regulations will be the biggest factor at changing racing by creating new overtaking opportunities." -- Geoff Willis --
With changes in aerodynamic regulations, change will come next year. Sad, this year was as close a championship as we'll see in our lives:
"We work 24 hours a day in the wind tunnel," said one team boss this week. "But we have hit a wall. We have only managed to find three percent more downforce this year. We just cannot find any more."
http://www.grandprix.com/ns/ns20651.html
On the other hand, an opposing view:
"In comparison with the hybrid technology of production vehicles, the concepts for motor racing are considerably more powerful, and at the same time more compact. We are already holding discussions with many teams from various racing series."
-- Klaus Böttcher, director Bosch Motorsport --
Nice article on Bosch KERS:
http://www.racecar-engineering.com/arti ... dular.html
Bosch four flywheel KERS. That's the energy storage unit, rated at 750 kilojoules: that's like 20 grams of gasoline give or take I estimate that over the course of the race, taking in account efficiency of ICE vs efficiency of electric motors, KERS should give you around 3-4 kilos of "extra gasoline"
I find this relevant for race strategy:
“A high charging rate means that you may also have very high cooling demands,
batteries with a low charging rate may survive with forced air cooling, high charging rates will mean liquid cooling” Wildner (from Bosch) explains. “
Mechanics will not be able to change cells trackside, though they they will be able to change the module. We won’t let them work directly with the cells as they are high voltage and low inner resistance and that could have safety implications.”
Are we going to see new inlets for KERS batteries? How will that affect the radiators and sidepods? Will batteries changed along the tyres if other manufacturers find how?
Another article by Racecar Engineering on the Magneti Marelli unit:
http://www.racecar-engineering.com/news ... -kers.html
Magneti-Marelli liquid cooled unit
It says it's "single liquid cooled brushless direct current motor generator unit", "fairly conventional".
I find remarkable that you can get 80 hp from an 8 kg electric motor (that's what many car engines deliver from a 100 kilos or more ICE!). Many people has heard me saying that they're the future of racing. Check the Bosch motor, taken from here:
http://www.greencarcongress.com/2008/11 ... lopin.html
Finally, long quote from Pedro Martínez de La Rosa:
Q: What does a 2009-spec car feel like to drive?
Pedro de la Rosa: It’s very different. Obviously, the slick tyres give you a lot more grip - so although we will be running with reduced downforce, the overall grip of the car won’t be that different to what we had. But it’s the balance front to rear that will change - the slick tyres have a very strong front-end going into the corners and they have very good traction coming out. Overall, to simplify things, I think the slick tyres will give us laptime in the low-speed corners and because of the reduced downforce we’ll be slower at high speeds.
Q: Do you think it will make overtaking easier?
Pedro de la Rosa: Yes, definitely. Considering this is Formula One - if people think the introduction of KERS and the reduction in downforce and slicks is going to transform Formula One, then forget it. It will still be a wide car, there will still be aerodynamic effect and offline will stay dirty. It will be easier, but it won’t be MotoGP. And people need to understand that.
The changes are headed in the right direction. The difficulty comes from having so many changes and a massive reduction in testing for next year. It will make fine-tuning your car between the races very difficult. It’s going to be very interesting - and there won’t be enough time to test everything.
http://www.formula1.com/news/features/2008/12/8754.html
