BMW Sauber F1.09
Re: BMW Sauber F1.09
Bob Brown wrote:
wesley123 wrote:The first F1 team to copy the Acura 'quillars', also there seem to be vertical fins on there with a small plane in between, probably this generates more downforce under jaw, just like the shark fins.
mini rear wing in the middle.......very very odd. Wonder if the rear wing will stall.
i dont think it will, remember this was usual in early 2000's. but then in full width so i odntt hink it will stall, but i dont know anything about stalling, so someone might have to explain me that before i can go for a conclusion here
zgred
zgred wrote:
axle wrote: Image
Can we expect smaller inlets?
Or just different shape due to more undercut in the sidepods?
More details.
ESPImperium
ESPImperium
64
I recon they have gone to more F1.08 style sidepods, as those were aero masterpices.
Im shure they have more aero advances, posibly a new frone wing and nosecone design as well.
The F1.09 pace can only get better.
zgred
New wing. Not really revolutionary but the nose...
al_kar
al_kar
God, that nosecone is VERY ugly
myurr
myurr
al_kar wrote:God, that nosecone is VERY ugly
Yeah - I didn't think they could make that car any uglier but by <insert deities name here> they've managed.
ESPImperium
ESPImperium
64
Congratulations to BMW Sauber. they have done the very imposible. Made a ugly car, even more repulsive.
If it works for times, my hat will come off if they improve significantly tho.
Scotracer
Scotracer
I think the new car looks better than the old one :? :D
Powertrain Cooling Engineer
Sawtooth-spike
what the hell is that "thing" on the Rear wing? errrrhhggg
Please dont let this car be fast, its to offensive!
Ignoring the asthetics, how is it legal to put a wing onto another wing. Maybe is falls under the same interpritation as the the front wing winglets
I believe in the chain of command, Its the chain I use to beat you till you do what i want!!!
Scotracer
Scotracer
Sawtooth-spike wrote:what the hell is that "thing" on the Rear wing? errrrhhggg
My guess is that section of the rear wing is void of such restriction so as to allow the teams mounting points for the supports.
Sawtooth-spike
Good point.
Its an interesting ... Support. Looks like the old days they had odd extra wing stuck to the back of the car
Scotracer
Scotracer
The rear wing has a pretty big gurney flap too.
Just checked the Tech Regs and there is an article:
3.10.2 Any bodywork behind a point lying 50mm forward of the rear wheel centre line which is more than 730mm
above the reference plane, and between 75mm and 355mm from the car centre line, must lie in an area
when viewed from the side of the car that is situated between the rear wheel centre line and a point
350mm behind it. When viewed from the side of the car, no longitudinal cross section may have more than
two closed sections in this area.
This allows a 150mm wide section that is not covered by the two-plane limit.
From MarioF1's images:
The area that isn't grey is where this may go.
wrcsti
wrcsti
Yo dawg we heard you like wings, so we put a wing on your wing so you can grip while you grip.
Scotracer
Scotracer
wrcsti wrote:Yo dawg we heard you like wings, so we put a wing on your wing so you can grip while you grip.
modbaraban
modbaraban
Wing supports seem to be inspired by Acura ARX2a and Audi R15.
