DaveKillens wrote:
So logically, a two cylinder engine has more friction than a single cylinder, and so on and so on.
To make a meaningful comparison, you have to define the hypothesis of the comparison, hence, a fixed total displacement, a given rpm, a given bore/stroke, same materials and generally the same technological level (to compare an excellent single with a crappy twin is pointless).
Then, given the hypothesis, you can isolate the number of cylinders as the main variable, and the result is : more cylinders = less friction.
DaveKillens wrote:
But the smaller the combustion chamber, theoretically, you can achieve more power.
It’s not the volume of the combustion chamber the variable making an engine with more cylinder to theoretically achieve more power, it’s the piston area.
Consider a single cylinder of given displacement and fixed combustion chamber volume (hence fixed compression ratio), the power theoretically achievable growths increasing the bore/stroke ratio, hence increasing the piston area. The same applies while comparing engines with different number of cylinders, the more cylinders the larger the piston area can be, everything else being equal, and this will allow to achieve more power.
DaveKillens wrote:
As far as beautiful engine sounds... an older Ferrari V-12 ( eg, a P4) is a very sweet bit of music.
Well, in the end there’s something we agree about.
riff_raff wrote:
However, as a general rule of thumb in engine design, for a given power output, a large displacement engine with a minimum number of cylinders running at slow speed, will be more efficient than a small displacement engine with a large number of cylinders running at high speed. This is because FMEP losses (mechanical friction, pumping losses, etc.) increase exponentially with engine speed.
The fallacy of this mythical argument, claimed over and over (alongside the senseless “longer stroke = more torque”) is that the “engine speed” you have to consider isn’t the engine rpm, it’s the piston average velocity; FMEP (only mechanical friction, to include also the pumping losses is a wrong, although sometimes adopted, approach) is proportional to a power between 2 and 3 of piston average velocity. The point in increase the number of cylinders is exactly the reduction of the stroke, hence of the piston average velocity for the same rpm, resulting in lower power losses at the same rpm; the same power losses will occur at the same piston average velocity hence at higher rpm, but there the engine with more cylinders will also give more power.
dumrick wrote:
Let's also not forget that FIA made the V10's mandatory. Otherwise, with the capacity reduction to 3 liters, I bet that some research would begin to be made again on V8's.
I think you would lose your money then, at the time the V10 was made mandatory because Toyota was planning to enter with a V12, not with a V8.
