Is it possible to have a valve which opens when air traveling through the duct reaches a certain speed?SZ wrote:You are.
Consider that you could theoretically stall the wing with some well-directed air, and that it'd be useful at speed.
Consider that there are times when you'd certainly not want this to happen either.
How does the system change between the two?
If this is potentially how it works, this is where it's potentially sinister... go on!
ringo wrote:The fin putting air on the wing wont be of much help. The air wont be a better quality of the free stream air. Stalling is also not desirable at any rate, the wing would behave like a bluff body only creating drag.
The air through the heat exchangers is not steady either and it loses most of the KE hitting into the grating of the exchangers.
What could work however, is if air was injected behind the wing, between the wing elments though a duct in the fin. This air would have to be at a higher pressure than that on the low pressure side of the wing. Introducing high pressure behind the wing would reduce the pressure difference between the sides of the wing, reducing drag and reducing lift. This only works if the enthalpy gained by the air going through the heat exchangers can restore most of the pressure and energy lost.
For it to work the injected pressure has to be higher than that behind the wing. the closer it is to free stream pressure the better. With equal pressure on both sides, ideally the wing would behave as if it was not there, no drag and no down-force.
Something like this:
The curved lines are the wing, red lines hot air, blue low pressure and free stream.
The drawing is a not dimensionally accurate, but you all should get the idea.
This reduction in drag and down-force thing is only desirable on the straights, when a DF reduction wont hurt.
The contention being.. if something is actively switching this effect on & off, is this counted as a moveable aerodynamic device...?bonjon1979 wrote:Is it possible to have a valve which opens when air traveling through the duct reaches a certain speed?SZ wrote:Consider that you could theoretically stall the wing with some well-directed air, and that it'd be useful at speed.
It would be classed as engine cooling, just like the wheel covers were classed as brake cooling ducts.Fil wrote:The contention being.. if something is actively switching this effect on & off, is this counted as a moveable aerodynamic device...?
Hmm.. high revs are used in each gear, even in mid-speed & slower corners.richard_leeds wrote:It would be classed as engine cooling, just like the wheel covers were classed as brake cooling ducts.Fil wrote:The contention being.. if something is actively switching this effect on & off, is this counted as a moveable aerodynamic device...?
Since it is a device for engine cooling you could legitimately open it when the engine is worked hard at high revs, and close it for low revs. Which happens to coincide with corners (high downforce) and straights (low downforce).
Ohh my... SZ created a monster with his seamingly socratic line of questioning...Darknight wrote:Adding to the inlet being blocked by the helmet, could it be that Brawn/Merc were hinting to this this when they were saying Rosberg "dropped 1.5cm" during the day. If Mclaren can control this drop and rise then cant they get the drivers helmet to block an inlet at will?
Can the drink button be used to pump fluid out from under the driver to lower him and opposite to raise him?
Perhaps they use the sensors mounted at the top of the car for static pressure?SZ wrote:Actually, on second thoughts is that rake pitot-static? I can only see one pressure tube out of the rake per position, unless the static channel is mounted on a common manifold.
Whats with the air box?thestig84 wrote:
Thoughts? Just simply because its still coldish at Jerez!?
