Golf ball aerodynamics in F1
ggajic
ggajic
Re: Golf ball aerodynamics in F1
Note dimples on ZIPP Firecrest 808 carbon bicycle wheels:
http://freshbikescycling.com/images_sto ... reABLC.jpg
I had this thought about dimples but I'm not sure about technical regulations allowing it..
flynfrog
Cocles wrote:Why not simply try this out on the axle rods?
add a bunch of stress risers to my axle, no thanks, you try it on yours. The axles are already faired in any way.
flynfrog
dimples like vortex generators ect. are usually done as a band aid when trying to push an airfoil to far. A smooth well designed airfoil will 99% of the time be more efficient than the same airfoil with all of the dimples and vortex generators you can imagine.
The dimples on a golf ball work better because it is a terrible shape for drag and lift and the dimples help keep the flow attached a little bit longer.
