automatic:
–adjective
1.having the capability of starting, operating, moving, etc., independently: an automatic sprinkler system; an automatic car wash.
Aside from the anti-stall system, I can not think of any way how the clutch can be called an automatic. It's response to driver's input is variable and can be adjusted in real time, but the driver still tells the clutch when to engage or disengage.
Automatic and full manual are not the only kinds of systems out there. The clutch may be electronically controlled, but there is still a switch that is controlled by the driver.
The regulations prohibit the teams from using an automatic clutch, but it does not require them to use a fully manual and mechanical clutch.
Your computer keyboard is electronically controlled too, and it types in "e" when you press the "e" button. It does not type "e" when it thinks the letter "e" should be typed in. Same with the clutch, it disengages the clutch to a certain position when you tell it too, but you still have to tell it to. It does not blend the clutch during starts out of its own accord.
