Singapore Grand Prix 2010 - Marina Bay
walter
walter
Re: Singapore Grand Prix 2010 - Marina Bay Street Circuit
Miguel wrote:You guys are legends! I was watching the BBC broadcast of Saturday Practice (15 minutes to go), and they specifically mentioned F1T about your caster explanation.
=D> =D>
FINALLY F1T getting the recognition it deserves
WhiteBlue
92
Vettel in a class of his own. Webber almost 1.2s behind.
Schumacher one s behind Rosberg
Heidfeld beats Kobayashi
Button a long way down the table
Because the session was ended 2 lap early by Senna's off, the other contenders didn't their final laps in. I suspect the Ferrari and Mclaren are about 0.2 to 0.4 seconds slower than the RedBull this time.
Byronrhys
Those times really mean nothing, anything shy of the top 8 weren't really pushing to me and Bruno just messed up the end of the session.
WhiteBlue wrote:Image
So what do you say WB? Vettel for the pole? 8)
cool ...at least there `s hope the hacks and journos do inform themselves about technical matter ...
As for the times..you need to take the last screen shown as only there you will see the best sector times but of course not the ideal time...
Schumacher did his best laps under yellow...so it might be a second but that is pure optics.adding up the sector best shows who is quick and who is able to string a set of sectors to a good laptime.
so adding up all the optium sectors schumacher would be 9th or 10th.
dougskullery
dougskullery
Is Red Bull's use of the retarded-exhaust engine map still limited to qualifying? If so, it'd be reasonable to expect an even bigger gap emerges between them an McLaren - who use it almost constantly - in Q3, though doubtless Macca will also run a more extreme setting in quali.
Chaparral
Gugs you would love that to be the case but its not you know that theres probably .1 sec between them wait till qualis and lets see if your so called wisdom is correct I doubt it
The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free and good men die like dogs - there's also the negative side' - Hunter S Thompson
Giblet
Giblet
Wisdom and unabashed manlove for Vettel are not mutually exclusive.
almost nobody has strung all the best sectors to a near perfect lap yet ...be it to hide potential or it is simply the fact they have done their best sectors with different settings.
Sauber looks quite slow compared to the other teams and Glock clearly has the measure of Lotus.
Could this be the event where he can drag Virginia (or what is her name?) out of the mud and show her beauty?
747heavy
analysis by www.f1fanatic.co.uk
- Colin Chapman
theblackangus
theblackangus
Giblet wrote:Wisdom and unabashed manlove for Vettel are not mutually exclusive.
Now that is some funny stuff.
On topic,
747 Heavy,
How can the ultimate times be slower than the fastest times?
Im confused:
Example:
Seb - ULap - 1:47:563
Seb - FP2 - 1:46:660
So are the ULap times from FP3 alone?
747heavy
theblackangus wrote: So are the ULap times from FP3 alone?
Yes, these are the ultimate laps of FP3 only
The times from FP2 are on the last page
- Colin Chapman
univex
univex
5LiveF1 Some big clouds now appearing around the circuit! http://yfrog.com/n5vyvyj
about 1 hour ago via Twitter for BlackBerry®
komninosm
komninosm
segedunum wrote:
komninosm wrote:Why all the conspiracy talks about HRT? Is there any reason they can't choose what driver they wanted to drive this GP and "had" to lie about food poisoning?
Because changing the driver they've already changed makes them look like arseholes, and if it appears to be done for money reasons it all but confirms that they won't be around for much longer?
Nonsense. Why would they look bad? Any team has a right to choose whatever driver they want for every race. This is business, it's not schoolyard kickball. Besides didn't the driver they replaced hit a pit crew member in the last race? Maybe he's psyched out a bit too. Also he might have had food poisoning days ago and be ok now (as Japaneses rags say), but a driver has to be ok from Thursday to compete properly so they changed him then.
