Actuation seems to be in the middle of the wing.
This cuts down on the weight of having 2 devices at each end plate.
I like the ferrari middle strut better, as it reduces the length and bends of piping required, since there can be a direct line from the gearbox going to the middle strut of the wing.
The force required is much larger this way, but the upper element doesn't carry more than 500lb of force.
Also as the element turns up, high pressure from the main element that overlaps with the front underside of the upper element will ease the required force as well.
Looking at the renault the pipe is probably 1/4 inch on the inside. 85 psi can give a force of pi*(1/4)^2/4 x 85, that's only 4lb; too little.
There has to be an expansion at the end of the pipe, as it seems to be flaring as it connects to the beam wing.
For about 500lb of force, the area has to be about 6 inches square.
That force is higher than what's on the element though.
http://motorsport.nextgen-auto.com/gall ... medium.jpg
for an elyptical airfoil shaped strut, then 6inch2 = pi *A*B ; A and B being the minor and major axis.
This all depends on the force required and the moment arm of the actuator and the element centre of pressure.
If we know the power of the system, we should be able to figure out how fast it deploys.
