Page 10 of 65
Re: [MVRC] Mantium Virtual Racecar Challenge 2018
Posted: 09 Aug 2018, 20:33
by CAEdevice
Wow, I noticed that there are new images of JJR car on the MVRC website. I am impressed and a bit frightened by his new front wing and high nose.
Posted: 10 Aug 2018, 01:41
by variante
Bombastic car! You can see that every bit you lay your eyes on is absolutely fine tuned!
Looks like it features some original details too, like that rear wing. Does it seek out efficiency in the same way airplane winglets do? What about scimitar winglets, then?
BTW it looks like I need a double element Rear Wing too in order to reach the right balance...
Posted: 10 Aug 2018, 04:28
by etsmc
The car has been submitted, but not hopeful for any results.
how are people doing all these cool images??
Posted: 10 Aug 2018, 06:13
by CAEdevice
variante wrote: ↑10 Aug 2018, 01:41
The scimitar winglets are there to feed the rear wing: they make efficiency worse, but they help with balance.
The airplane winglets give very small drag reduction (0.01...) by reducing the vortices at the sides of the wing, but the modeling and fine tuning of the wing is more difficult.
Posted: 10 Aug 2018, 09:17
by JJR
CAEdevice wrote: ↑09 Aug 2018, 20:33
Thanks Matteo. I ´m not sure if I will use that car. I have another with more traditinonal design. Actually I have problem to balance it and cooling which is too dragy for Le Mans. It is good for high downforce tracks.
Posted: 10 Aug 2018, 09:21
by machin
JJR wrote: ↑10 Aug 2018, 09:17
I had a look and couldn’t find it... do you have a link?
Posted: 10 Aug 2018, 09:40
by CAEdevice
machin wrote: ↑10 Aug 2018, 09:21
Hi, you can find the pictures in the "teams" section of the MVRC website.
Posted: 10 Aug 2018, 11:52
by machin
Ah, cool, thanks...
Looks good...
Posted: 10 Aug 2018, 19:12
by wpsiatwin
This is probably a dumb question but when the rear wing and diffuser strakes are submitted as separate stl files how do we ensure they are placed correctly for the CFD run?
Posted: 10 Aug 2018, 19:39
by RicME85
when you export them they keep their position on the X,Y,Z axis so the software knows where they should be. If you use the MantiumFlow software and import the STLs into it you will see this.
Posted: 11 Aug 2018, 09:17
by LVDH
Ok guys,
I have sent out a one day warning email also containing the submission link. Thanks to this new EU data privacy law, there is a double opt-in requirement to the MVRC emails. Not everybody has chosen to receive these emails, which is fine and up to you. Mainly you are missing the submission link. If you do not want to receive these emails, please make sure to submit your design by your own means and in time!
Posted: 12 Aug 2018, 15:14
by RicME85
Do we still have submission jokers this season? If so can I play mine already? I am stuck in bed, in a lot of pain so cant do use my PC.
Posted: 12 Aug 2018, 16:51
by LVDH
I guess so, why not.
Posted: 12 Aug 2018, 17:58
by Ft5fTL
etsmc wrote: ↑10 Aug 2018, 04:28
I used keyshot for the last renders.
Posted: 13 Aug 2018, 00:18
by Zynerji
https://www.pcworld.com/article/3295003 ... tures.html
Would MantiumFlow take full advantage of this new processor?
