Page 10 of 15
Re: Red Bull Power Unit Hardware & Software
Posted: 17 Jan 2026, 11:35
by Vappy
17 Jan 2026, 06:33
What I would like to know is whether or not the intercooler is inside the V. In theory you would do this to reduce the turbo lag. You want the shortest distance possible between the compressor outlet and the cylinder intake port. Therefore I cannot imagine that Red Bull would keep the sidepod mounted intercoolers from last season.
As sidepods are very useful for managing air flow and front tyre wake, or at least keeping it away from certain areas as much as possible, it's a space that's worth making use of. The intercooler is particularly large and I would struggle to think how that would fit, while accomodating the air intake.
Posted: 20 Jan 2026, 01:15
by BassVirolla
17 Jan 2026, 06:33
Turbo lag is nearly not affected by intake plenum / piping volume, but the inertia of the rotating components of the turbo.
A 1.6 engine at 11.000 rpm ingests 146,7 litres of air per second (at whatever boost you can or want put it). Not a big problem to have 10 or 20 litres of piping to fill.
While the engine stays above turbo threshold rpms (minimum rpm at which the turbo generates a positive feedback of air flow into and out of the engine) intake volume is a minor contributor to lag (being lag the time lapse between stepping on the throttle and getting the full achievable torque at current rpms).
Posted: 20 Jan 2026, 12:21
by Hoffman900
BassVirolla wrote:
20 Jan 2026, 01:15
17 Jan 2026, 06:33
This. RPM sweep rate is likely over 2000rpm/s in lower gears. Then the whole thing has to change near instaniously at shift recovery.
Acceleration isn’t a straight line. Should be easy for people with data to figure out.
Posted: 20 Jan 2026, 16:33
by BassVirolla
Hoffman900 wrote:
20 Jan 2026, 12:21
BassVirolla wrote:
20 Jan 2026, 01:15
17 Jan 2026, 06:33
I'm sorry, but I'm not catching your point at all. What has to change? What do you mean by shift recovery?
Are you thinking that lag will or will not be important? What about turbo threshold?
Seriously, I feel so sorry, but I don't understand a thing, nor why you quoted me (possibly because I'm not fluent in english language / culture and there is something implicit that is flying over my head).
Posted: 20 Jan 2026, 16:45
by Badger
First sounds of the RBPT-Ford.
Posted: 20 Jan 2026, 18:58
by FW17
engine sounds better than all the other engines we have heard. Louder too.
Posted: 20 Jan 2026, 19:25
by AR3-GP
I must be the only one who can't detect any difference in sound between this year and last year.
Posted: 20 Jan 2026, 19:32
by Emag
20 Jan 2026, 19:25
I don't notice any big difference either. As a whole, the power unit might be a little more "hissy" at the higher end due to more battery deployment (similar to what the LMP cars sound while building up speed), but the ICE sounds pretty much the same as it did before.
Posted: 20 Jan 2026, 21:19
by lio007
This does not sound very smooth:
Posted: 20 Jan 2026, 21:36
by Vappy
When Honda came out with their engine with McLaren, it sounded very much like that, even up to higher revs. It almost sounded like the turbine was off centre, and it's a similar sound in that video. If I find an example of this, i'll edit this post
Posted: 20 Jan 2026, 22:18
by lio007
Vappy wrote:
20 Jan 2026, 21:36
I know...all but healthy.
Posted: 20 Jan 2026, 23:16
by AR3-GP
lio007 wrote:
20 Jan 2026, 21:19
https://twitter.com/i/status/2013615304404824343
There are other videos
Posted: 21 Jan 2026, 00:29
by Vappy
lio007 wrote:
20 Jan 2026, 22:18
Vappy wrote:
20 Jan 2026, 21:36
Agreed, and the above video does sound particularly rough. It's reasonable to assume they weren't running anything particularly punchy for the above video, which looked like a simple outlap and back to the pits. Once it was up to speed I didn't hear any misfire or hesitation.
Happily, the racing bulls have done testing as recent as last year at this track, so i'll look at some comparisons tomorrow between this video and that one.
Posted: 21 Jan 2026, 10:21
by GhostF1
20 Jan 2026, 23:16
lio007 wrote:
20 Jan 2026, 21:19
It sounds extremely unwell. Very reminiscent of the 2015 Honda when it was spitting the dummy. The same sputtering and definite misfires going on there when it shouldn't be. Hopefully all software related!
Striking resemblance to Jerez 2015 ^
Posted: 21 Jan 2026, 10:43
by ME4ME
17 Jan 2026, 06:33
Now that we've seen the VCARBs airbox it's indeed likely that they've put the intercooler inside the v or at least above the engine.
