Page 101 of 216
Re: Renault V6 Power Unit
Posted: 02 Jul 2017, 12:54
by 63l8qrrfy6
carisi2k wrote:
02 Jul 2017, 00:48
Godius wrote:
01 Jul 2017, 13:32
Incorrect, in this interview he states that the failure was oil-pressure related, it was not caused by debris. The debris flew away from VES his radiator already in lap 3. That's why they did not box him just like RIC.
Can you not join the dots. The oil pressure issue was most likely as a result of that debris for 3 laps. Regardless of if the debris cleared the damage was done during those 3 laps. Oil temperatures rose and Max didn't help the situation by sitting right up the rear end of perez immediately after and the engine heat from Perez drove the final nail into the coffin and then instead of coming into the pits immediately he did an extra lap for some reason.
Although this sounds plausible I find it hard to believe that the team failed to notice dangerous temps. I think they would have called him in right away had they thought there was a risk of damage.
Posted: 02 Jul 2017, 14:04
by carisi2k
Mudflap wrote:
02 Jul 2017, 12:54
The debris cleared itself and so the temperatures would have went back down, but the damage was already done and with Max being Max he pushed up to perez close after the temps came back to normal and the engine just wasn't ready for another spike yet and let go.
I'm not saying Max is at fault, but I don't think Red Bull or Renault should be blamed either in this situation. Red Bull was running low drag to keep up with the Mercedes powered vehicles and this probably meant reduced cooling tolerances.
Posted: 02 Jul 2017, 14:15
by ME4ME
carisi2k wrote:
02 Jul 2017, 14:04
Teams are always on the limit regarding cooling. Baku is no different.
Posted: 02 Jul 2017, 14:32
by PlatinumZealot
carisi2k wrote:
02 Jul 2017, 00:48
Godius wrote:
01 Jul 2017, 13:32
How do you make out a hot engine to cause low oil pressure?
Posted: 02 Jul 2017, 16:58
by godlameroso
Because hotter oil has lower viscosity, and less resistance for the oil pump to push oil past bearings.
That doesn't really apply to these engines, if there is an oil pressure problem you have bearing issues or a leak somewhere.
Posted: 16 Jul 2017, 12:14
by godlameroso
Is Hulkenberg using a new spec engine or something? I find it curious that his car is almost as fast as the Red Bull.
Posted: 16 Jul 2017, 13:51
by Swobber
godlameroso wrote:
16 Jul 2017, 12:14
Maybe its the new floor?
Posted: 26 Jul 2017, 09:58
by f1316
Swobber wrote:
16 Jul 2017, 13:51
godlameroso wrote:
16 Jul 2017, 12:14
What's interesting to me is that the works Renault team are consistently better in quali than race; I wonder if they have a better quali map than their customers (ala Merc)?
Posted: 26 Jul 2017, 14:23
by wuzak
f1316 wrote:
26 Jul 2017, 09:58
Swobber wrote:
16 Jul 2017, 13:51
godlameroso wrote:
16 Jul 2017, 12:14
Or Hulkenberg is an ace qualifier but so-so racer?
Or the car wears its tyres to much in races?
Posted: 29 Jul 2017, 18:08
by PlatinumZealot
Renault were always good at susepnsion tricks. So the chassis shines on tracks such as theses. That fact that they are close to RedBull today more indicates improved aerodynamics. For the poor race pace, i can only guess that they need just a bit more understanding of their aero balance (it is a new kit afterall) and of course tyre temperature management. Knocking on what Wuzak said too, Hulk while good at generating tyre heat over one lap, he was never great at managing his tyres over a race. See hulk V perez at force india.
Posted: 03 Aug 2017, 15:14
by Blackout
Didnt you watch the last two races? Now the Renault has also a good race pace thanks to the latest aerodynamic updates which have greatly changed the characteristics of the car.
Posted: 14 Aug 2017, 15:09
by dren
Renault changed too much of their PU which caused the reliability issues this year. Sound familiar?
http://www.autosport.com/news/report.ph ... e-for-2017
Posted: 22 Aug 2017, 09:39
by skoop
So Renault will bring updates to Spa/Monza:
https://www.autosport.com/f1/news/13133 ... ne-updates
Posted: 23 Aug 2017, 00:55
by carisi2k
skoop wrote:
22 Aug 2017, 09:39
If the engine is any good I would say it is a safe bet that Red Bull would take the penalties since they are so far behind Mercedes and Ferrari and so far ahead of Force India and the mid pack. Anything that could help them for 2018 would be worthwhile for testing in 2017.
Posted: 04 Sep 2017, 15:59
by Blackout
The Renault intake plenum* has an odd shape. Bell said they have found an interesting solution in that area (for the air supply or was it for the cooling?)
*Or is that another intecooler (placed in front of the manifold) you can see one the sidepod-intercooler-to-the-manifold pipe, with the green cap, just behind that thing
https://twitter.com/Albrodpul
