carisi2k
Re: Renault V6 Power Unit
ArcticWolfie wrote:
26 Jun 2017, 15:54
3 Renault PU failures yesterday... not really a good prospect and I thought they were working hard on the reliability.
To be fair to Renault. Max's problem has been linked to debris from other incidents restricting air flow and the fact he got too close to the back of perez just before his engine did blow.
Godius
186
carisi2k wrote:
30 Jun 2017, 07:30
ArcticWolfie wrote:
26 Jun 2017, 15:54
Marko’s initial belief was that debris could have contributed to Verstappen’s failure but that was not the case:
https://www.motorsport.com/f1/news/red- ... ko-924384/
wuzak wrote:
30 Jun 2017, 04:18
30 Jun 2017, 01:04
lawnmower wrote:
24 Jun 2017, 09:57
Abiteboul said it was 0.2 seconds. Is this possible with a software update?
The "spark plugs" are free to change... so you know what that means..
They put in new spark plugs?
The TJI torch and all it nozzles and shrouding is the "spark plug" It has a strong effect on combustion. You can change it freely without changing engine. It is a loop hole.
3jawchuck
3jawchuck
37
30 Jun 2017, 21:27
wuzak wrote:
30 Jun 2017, 04:18
30 Jun 2017, 01:04
Spark plugs, injectors and fuel rail ancillaries are all free to change anyway.
ME4ME
79
https://www.motorsport.com/f1/news/f1-n ... ty-924897/
Traffin:
“There is still a big focus in trying to follow our road map and make sure that next year’s engine is there. And as it is an engine that is close to this one, it is easier to transfer ideas from one to the other.”
Two weeks ago Abiteboul said in 2018 Renault would be bring a complete new concept PU. :wtf:
Godius wrote:
30 Jun 2017, 07:45
carisi2k wrote:
30 Jun 2017, 07:30
ArcticWolfie wrote:
26 Jun 2017, 15:54
In the original German Interview he said the problem was indeed caused by a debris... http://www.auto-motor-und-sport.de/form ... 93178.html
hurril
hurril
30 Jun 2017, 21:27
wuzak wrote:
30 Jun 2017, 04:18
30 Jun 2017, 01:04
Are you sure about this?
Yes Renault pulled the same card last year. They change TJI nozzles.. And put it as a "spark plug" update... That spark plug change gave them a few more tenths of laptime. I can't remember the race when it happened. Either Monaco or the update after that.
lio007
323
01 Jul 2017, 02:36
I think it was in Singapore, but as far as I can remember RB didnt race them because driveability decreased.
baybars
baybars
Does anyone have info about engine rules at test.
As you know Redbull tested 2018 tires with 2017 car.
Can Redbull use new upgraded motor in this test? is it possible?
FPV GTHO
FPV GTHO
Don't see why not, a test isn't going to count towards their race engine allocation, and there's no more tokens to restrict development.
Godius
186
Blackout wrote:
30 Jun 2017, 23:08
Godius wrote:
30 Jun 2017, 07:45
carisi2k wrote:
30 Jun 2017, 07:30
Incorrect, in this interview he states that the failure was oil-pressure related, it was not caused by debris. The debris flew away from VES his radiator already in lap 3. That's why they did not box him just like RIC.
wuzak
wuzak
475
FPV GTHO wrote:
01 Jul 2017, 13:08
They're not supposed to test new parts at Pirelli tests.
Dazed1
Dazed1
Godius wrote:
01 Jul 2017, 13:32
Blackout wrote:
30 Jun 2017, 23:08
Godius wrote:
30 Jun 2017, 07:45
Hmmm. "It was a big piece of carbon fibre, but it blew away, unfortunately after three laps.”
UNFORTUNATELY sounds more like he is blaming debris. ??
carisi2k
Godius wrote:
01 Jul 2017, 13:32
Can you not join the dots. The oil pressure issue was most likely as a result of that debris for 3 laps. Regardless of if the debris cleared the damage was done during those 3 laps. Oil temperatures rose and Max didn't help the situation by sitting right up the rear end of perez immediately after and the engine heat from Perez drove the final nail into the coffin and then instead of coming into the pits immediately he did an extra lap for some reason.
