Re: Ferrari Power Unit
Posted: 20 Jul 2018, 11:48
Are you sure? I remember that at least freewheel is legal, so you could spin only compressor and not turbine with MGU-H. With freewheel and low enough gear ratios I'd think that all-electric compressor driving is perfectly legal. And if it's legal it's the way to do it and every other should immediately go that route too as they could greatly improve MGU-H efficiency.wuzak wrote: ↑20 Jul 2018, 11:46No.naukkis wrote: ↑20 Jul 2018, 11:05
Is this legal in F1?
This is great innovation if it's legal, and might be reason for double wiring from battery. By decoupling compressor from turbine turbine efficiency ratio can be greatly increased by letting turbine to spin at best efficiency rpm range all the time. This is a great innovation.
Good idea, but not possible under current regulations - you can have only one MGU-H (you need two for this) and turbo must be on the same crankshaft as compressor...naukkis wrote: ↑20 Jul 2018, 12:04Are you sure? I remember that at least freewheel is legal, so you could spin only compressor and not turbine with MGU-H. With freewheel and low enough gear ratios I'd think that all-electric compressor driving is perfectly legal. And if it's legal it's the way to do it and every other should immediately go that route too as they could greatly improve MGU-H efficiency.wuzak wrote: ↑20 Jul 2018, 11:46No.naukkis wrote: ↑20 Jul 2018, 11:05
This is probably used as the flow from K to ES is limited to 2MJ, so if you can generate more than 2MJ under breaking by K, the rest must go by the K-H-ES path...restless wrote: ↑20 Jul 2018, 10:28Slightly offtopic - I can't remember if transfer of energy K ->H -> ES was ever discussed?
What if on same tracks this could be beneficial?
After all, we expect MGU-H generation to be somehow limited :S
Unless ferrari made some breakthrough in this area - like regenerating x times more energy from heat...
Most good ideas in F1 are about loopholes. What about one crankshaft which has MGU-H sitting both sides where axle freewheel is located - is there any regulations which prohibits such a arrangement. Energy flow can only be from or to MGU-H but if energy is made and consumed inside it....
This K-H-ES path isn't exactly loophole, H can only make or consume energy, it can't flow through it. It probably can go around regulations by accelerating H with energy from ES and then extracting it from H to K but it's not the most efficient way to do it, and achieving constant flow will need some capacitive buffering too.
The turbine and compressor are connected by a shaft, not a crankshaft (which is found within the engine).naukkis wrote: ↑20 Jul 2018, 12:29Most good ideas in F1 are about loopholes. What about one crankshaft which has MGU-H sitting both sides where axle freewheel is located - is there any regulations which prohibits such a arrangement. Energy flow can only be from or to MGU-H but if energy is made and consumed inside it....
Engine needs exact amount of air, which is what rpm turbo has to rotate. H is regulating to that rpm and extract what is excess to power compressor.Tommy Cookers wrote: ↑20 Jul 2018, 12:55naukkis seems to have said that the turbine isn't always at the best rpm
but isn't the H continuously either motoring or generating to a degree such that the turbine is always at the best rpm ?
One of the “H” 3 primary jobs is to control turbo speed/boost, either spooling it up or slowing it down, one other is, when exhaust gasses that are powering (spinning) the turbine is in excess of what boost the engine needs the “H” which is on the same shaft and rotates at the same speed will harvest energy, yet another function of the “H” is to spin the turbo (compressor) in solely electric supercharging mode while the waste gates are open and the exhaust gases are bypassing the turbine.Tommy Cookers wrote: ↑20 Jul 2018, 12:55naukkis seems to have said that the turbine isn't always at the best rpm
You can also use the route ICE-K-ES.Mr.G wrote: ↑20 Jul 2018, 12:25This is probably used as the flow from K to ES is limited to 2MJ, so if you can generate more than 2MJ under breaking by K, the rest must go by the K-H-ES path...restless wrote: ↑20 Jul 2018, 10:28Slightly offtopic - I can't remember if transfer of energy K ->H -> ES was ever discussed?
This approach was discussed in some detail in the Honda PU thread, starting at page 845.naukkis wrote: ↑20 Jul 2018, 12:33This K-H-ES path isn't exactly loophole, H can only make or consume energy, it can't flow through it. It probably can go around regulations by accelerating H with energy from ES and then extracting it from H to K but it's not the most efficient way to do it, and achieving constant flow will need some capacitive buffering too.
