Re: Formula E
Posted: 28 Apr 2022, 20:00
Official livery of Envision Racing
Okay, that's a motorboat with wheels, not an aircraft carrier
This is slowly getting closer to the concept they should have started with. Lose the F1 wannabe style so they are not so fragile....maybe a cross between TA and WRC. Add torque vectoring. Then let them beat, bang, and recharge around the city street confines they inhabit.The Gen3 car will be lighter...maximum power output of 350kW, capable of a top speed of over 320kph (200mph).
It will feature two powertrains β one at the front and rear β which will more than double the regenerative potential of the car compared to the current model.
Seems rather silly.jjn9128 wrote: β30 Nov 2021, 12:22Yes, no idea why.MattWellsyWells wrote: β30 Nov 2021, 12:05So is the front powertrain only used for regen and not drive?
Yeah, F1 is getting rather silly with proportions and mass....
Apparently by having front regen (but no power) they can lose some of the battery.mzso wrote: β28 Apr 2022, 22:41Seems rather silly.jjn9128 wrote: β30 Nov 2021, 12:22Yes, no idea why.MattWellsyWells wrote: β30 Nov 2021, 12:05So is the front powertrain only used for regen and not drive?
Wouldn't some mechanical linkage to the back make sense, since they don't drive the front?
They wouldn't need more batteries, since they have a powet cap, 4WD would allow to use it better even. So probably slightly even less battery/weight.Sevach wrote: β28 Apr 2022, 23:00Apparently by having front regen (but no power) they can lose some of the battery.
If they had the front powering the wheels they would probably need even more battery and the car would be heavier.
The way they are doing it they can brag about "more power +better autonomy -weight".
The front motors only need to feed the battery in the end.
You forgot to congratulate Mercedes - he was driving for them and they won the constructor title.Wouter wrote: β14 Aug 2022, 12:59SEOUL, KOREA
STOFFEL VANDOORNE THE 2021-22 FORMULA E
WORLD CHAMPION!![]()
https://pbs.twimg.com/media/FaHPKtIacAA ... name=large
https://pbs.twimg.com/media/FaG0c7lXEAA ... name=small
https://pbs.twimg.com/media/FaG8UzwXkAQ ... name=small ... https://pbs.twimg.com/media/FaG8UzvXkAA ... name=small
.Just_a_fan wrote: β14 Aug 2022, 13:59.Wouter wrote: β14 Aug 2022, 12:59SEOUL, KOREA
STOFFEL VANDOORNE 2021-22 FORMULA E
You forgot to congratulate Mercedes - he was driving for them and they won the constructor title.![]()
