Posted: 01 Aug 2018, 22:10
Who said anything about going outside of the regulations? I certainly did not. And why would teams not try to bypass something when there is an allowable way to do it (in this case the K <> H <> ES path)? Seems to me that would just be a bit naive on their part.saviour stivala wrote: ↑31 Jul 2018, 21:04"So that the teams can bypass the ES<>K limit" It is hard for me to believe that any of the four manufacturers (and not teams) will try or be tempted to try to bypass any limit imposed by the regulations.subcritical71 wrote: ↑31 Jul 2018, 15:27This could be the extra harvest mode. There are two things;saviour stivala wrote: ↑31 Jul 2018, 13:11So now we have something else added to the “Honda harvests even under power” of which I said it was legal/permitted, as evidenced and done in Hungary by Vandoorne. What was added now is that Honda harvests 3MJ through the MGU-K and this on black on white. How Honda can or is allowed to harvest 1MJ more than is permitted by the MGU-K and gets it post the FIA flow measuring sensor is beyond me. I am saying this because when I look at the FIA energy flow chart the charts show flow from engine to MGU-K and from MGU-K to engine being stated as limited, and as I also understand it, it is because this flow is limited that a flow measuring sensor is mandated at the MGU-K.
Somebody mentioned “clipping”. Clipping happens when all the energy in the ES is used-up and the MGU-H clicks-in (comes on-line). Those that their turbo/MGU-H combination allows the MGU-H to click-in/comes on-line, their MGU-H will be rapidly re-charging the ES, those that their turbo/MGU-H combination does not allow this, they will normally have to revert to harvesting by the MGU-K under power/by burning fuel,
1) energy is sent from the K to the H and then on to the ES. The energy from K to H is unlimited as is the pathway from H to ES (K still limited to +/-120w power).
2) Honda have shown they are able to switch the H from generating to supercharging mode at a rate of 20 to 40 Hz (switches every 25 to 50 msec). This is the method of temporarily storing energy (inertia, electronics) so that the teams can bypass the ES <> K limits.
henry has some good posts on how the energy flows could be calculated based off of time delays for when the energy is sent to when it arrives at battery. From the data I've seen on a similar energy sensor used in FE, the sampling rate can be as high as 1000 Hz (1 msec), so fast enough by a wide margin for the known Honda switching rate.
Please refrain from posting incorrect or misleading information. This will only confuse others that come to this forum and don’t realize the source.saviour stivala wrote: ↑01 Aug 2018, 14:43Max energy released per lap (MGU-K) 4MJ.
Power output (HP) (MGU-K) 160HP for 33.33 seconds per lap.
I believe Ferrari's experience with their hybrid FXX cars has given them the advantage. They aren't circumventing any rules but simply moving in-between the rules.saviour stivala wrote: ↑01 Aug 2018, 14:43
I might be wrong but I can only tell that of what I see.(rules/regulations/ energy flow chart).
Energy store, ES where all energy recovered by K and H is stored.
Max output per lap (MGU-K) 120KW.
You must have missed the big curved line going from the MGUH to the MGUK, via the control electronics, with the word "unlimited" in the middle.saviour stivala wrote: ↑01 Aug 2018, 14:43I might be wrong but I can only tell that of what I see.(rules/regulations/ energy flow chart).Cwesh wrote: ↑31 Jul 2018, 20:48The K to engine and engine to K are only limited in kW. There is no limit in MJ at that point of the flow chart. The MJ limits are for K to ES and ES to K.saviour stivala wrote: ↑31 Jul 2018, 18:41"The energy from K to H is unlimited" Yes that is what the flow chart shows, the flow chart also shows that engine to K as limited, as well as K to engine as limited. the K operates as a motor by being supplied either from ES or H, but the K operates as a generator by the engine (is powered/rotated by crankshaft) and it operates this way when the brake pedal is pressed.
Yes for the fuel, but it doesn't mean that maximum boost is generated, or the extreme a:f ratios we have come to know from TJI is being exploited at the lower rpms. If there is some data or graphs available we can see if the max fuel flow is being used at the lower range, and also if the lean a:f is being maximized as well.
I have another idea, one that makes more sense.sosic2121 wrote: ↑02 Aug 2018, 09:05"Other systems treat their battery as one. Ferrari, it's one battery, but they treat it as two. That's the fundamental difference, I don't think it's a secret I'm giving away there."
I am still to hear convincing explanation about this. Heat management, separate K&H battery... I don't think so.
The only difference is how system treats this ONE battery.
Maybe they can rearrange connections between cells in order to manipulate voltage/current output in order to increase efficiency of the system(mainly CE) depending on H&K needs.
(for example in turbo compound mode ES outputs 60kw, and in e-charger mode it outputs 180kw)
Technical regulations 2017 5.12.5 the maximum peak voltage on the car must never exceed 1000v.sosic2121 wrote: ↑02 Aug 2018, 12:41I have another idea, one that makes more sense.sosic2121 wrote: ↑02 Aug 2018, 09:05"Other systems treat their battery as one. Ferrari, it's one battery, but they treat it as two. That's the fundamental difference, I don't think it's a secret I'm giving away there."
Couple assumptions:
-batteries are always kept between 40% and 70%(where they are most efficient), and that implies voltage per cell is 3.6-3.7V
-charging voltage per cell is 4.2V(maybe more)
-maximum allowed voltage is 800V DC?
(can someone confirm this)
Since cable losses rise with square current, it would be beneficial it increase charging voltage to maximum 800V.
But that would mean that battery voltage is only cca. 700V.
That means current is 13.5% higher, and cable losses are 28% higher then they would be with maximum allowed 800V battery.
So if Ferrari could rearrange connections between the battery cells in order to manipulate battery voltage, they could have thinner and lighter cables, more energy and less heat.
Interesting concepts. Here's the regulation on voltage;sosic2121 wrote: ↑02 Aug 2018, 12:41I have another idea, one that makes more sense.sosic2121 wrote: ↑02 Aug 2018, 09:05"Other systems treat their battery as one. Ferrari, it's one battery, but they treat it as two. That's the fundamental difference, I don't think it's a secret I'm giving away there."
Couple assumptions:
Thank you both (subcritical71 and saviour stivala) for your input!subcritical71 wrote: ↑02 Aug 2018, 16:065.12.5 The maximum peak voltage on the car must never exceed 1000V.
Sorry about the double post. SS post wasn’t there when I posted and they appeared out of no where, but his time stamp is hours before....sosic2121 wrote: ↑02 Aug 2018, 16:45Thank you both (subcritical71 and saviour stivala) for your input!subcritical71 wrote: ↑02 Aug 2018, 16:065.12.5 The maximum peak voltage on the car must never exceed 1000V.
Thank you for pointing out that info I had was wrong!subcritical71 wrote: ↑02 Aug 2018, 18:28Sorry about the double post. SS post wasn’t there when I posted and they appeared out of no where, but his time stamp is hours before....sosic2121 wrote: ↑02 Aug 2018, 16:45Thank you both (subcritical71 and saviour stivala) for your input!subcritical71 wrote: ↑02 Aug 2018, 16:065.12.5 The maximum peak voltage on the car must never exceed 1000V.![]()
