Page 171 of 216
Posted: 17 Jan 2019, 03:31
by carisi2k
Blackout wrote:
16 Jan 2019, 15:53
According to this https://motorsport.nextgen-auto.com/Les ... 33854.html
Mercedes peak power = Ferrari = 1030 hp in qualy and 980 hp (race - average)
Renault 990 hp and 950 race.
Honda 950 hp and 930 race
But I dont know his sources.
Abiteboul said Renault lacks around 50 hp (Q) and that Honda is around 30hp behind Renault.
If Renault had anywhere near these numbers then why was Red Bull not closer to Mercedes and Ferrari in Q3. The Renault and Honda numbers are complete nonsense. Renault was nowhere near 30hp ahead of Honda because if they were then how was the Toro Rosso faster in a straight line at most circuits in 2018. Even with the amount of downforce the red bull creates it wouldn't lose out in straight line speed if it had 30hp spare on the Toro Rosso.
In conclusion you should take these numbers and Cyrils claims as bogus.
Posted: 17 Jan 2019, 06:22
by Blackout
carisi2k wrote:
17 Jan 2019, 03:31
Blackout wrote:
16 Jan 2019, 15:53
First this is wrong, the STR was faster in some circuits
Second; the STR, since almost 10 years, was often faster than The RB even with the same engine on the straights, because it simply generates less DF and drag.
Third, I dont take Abiteboul claims for granted but what he says here is 100 times more credible than Markos BS who claims "Honda (the 2018 Honda) is now Better than Renault"... maybe the spec 3 Honda developped more peak power than the Renault in one or two qualy sessions (still doubtful), but that doesnt mean that Honda, which changed engines every two gp, has a "better" allround package (race power, reliability, consumption etc). Even Gasly in Brazil (whos spec 3 STR vanished in the race, just like in Austin and Suzuka) said they lacked 25kmh to Sainz's Renault in the race.
Posted: 17 Jan 2019, 08:05
by Thunder
Reminder: This Thread is about the Hardware and Software of the Renault PU. Laptime (or Top Speed) Discussion of different Cars with different Engines is slightly misplaced here.
Posted: 17 Jan 2019, 23:47
by carisi2k
Are there any significant changes with this new 2019 Renault power unit I wonder?
Posted: 18 Jan 2019, 08:04
by Thunder
OK some Off Topic Posts have been removed.
Reason: About 10 cm higher on your Screen ;)
Posted: 18 Jan 2019, 23:03
by Walkman
carisi2k wrote:
17 Jan 2019, 23:47
The whole unit is apparently a complete revamp. The design has started in 2017 and has been running on dynos throughout 2018.
The thing is Renault seems to have some power available but the problem they foresaw a bit ago is that their engine topology just couldn't handle it, thus why the Spec-C was less powerful than expected and also less reliable.
We'll see how it goes.
Posted: 18 Jan 2019, 23:21
by trinidefender
Thunder wrote:
18 Jan 2019, 08:04
I think the moderators opinions (and that's all they are) are misplaced to say that trying to gauge power levels of the particular PU in relation to others is misplaced here.
Analysis of speed trap data aggregated between different cars and using different parts of the track is probably the only means that we have of estimating a PU's power. The more samples of similar conditions that we have, the more accurate the estimate. One the removed posts attempted to use this method by using a point (read speed) that minimises the errors of drag and traction. Please explain how this isn't relevant.
If that is the premise that is set then you might as well remove every post that has a guess of the PU hp/kW. I believe that your blanket statement that you cannot state it because it is off topic is totally out of line as it is the only factual data that we have that estimations can be made on.
This is an open challenge to the moderators to explain their logic why speed trap or similar data is off topic while wild speculation with no basis isn't considered off topic.
/end rant
Posted: 19 Jan 2019, 01:43
by Webber2011
trinidefender wrote:
18 Jan 2019, 23:21
Thunder wrote:
18 Jan 2019, 08:04
/end rant
While I tend to agree with you, forums can quickly degenerate if every querie about moderation is dealt with in public.
Perhaps this would be better sorted through pm's ?
Just my two bobs worth.
Posted: 19 Jan 2019, 10:37
by Juzh
Thunder wrote:
18 Jan 2019, 08:04
Ok, you removed my post which had some solid points in it and, yes, by the topic's title it probably shouldn't be here. But where exactly should it be then? After all it is a renault power unit thread and my post directly pointed out an aspect of said power unit (real life performance in this particular case) and gave a counter argument to another poster's clearly misleading reasoning :?:
Posted: 20 Jan 2019, 15:53
by subcritical71
:idea: 2014-2020 Formula One 1.6l V6 turbo engine formula -> viewtopic.php?f=4&t=9259
Posted: 22 Jan 2019, 12:20
by Espresso
Walkman wrote:
18 Jan 2019, 23:03
carisi2k wrote:
17 Jan 2019, 23:47
Although Abiteboul doesn't directly speak it out (so political...) he was only limiting his remarks to the Renault factory team.
He said Renault couldn't get more power out of the spec C....with BP/Castrol.
He does not, deliberately, mention in any way that the Spec-C was more powerful with ExxonMobil.
For the spec B the BP/Castrol seems to perform better then with ExxonMobil.
That was a fact he didn't forgot and rubbed it in to everybody listening.
But with 2 different strategies its comparing apples and pears. Red Bull ran the engines on or over the design limits to score podiums (and subsequently engine failures) rather then Renault who took a defensive approach and focused on scoring points.
According to Abiteboul it was the architecture design limits of the (current/previous) engine concept, no further evolution possible, that made Renault decide to build an al new engine (concept) for 2019 (deja vu...have heard this before the past years....)
We cannot call this an evolution or revamp of a previous concept as it's an 'all-new engine' design they started in 2018.
And involving almost all engine components.
"Given the ambition in terms of power improvement for next year, pretty much all of the engine will be new," added Abiteboul.
I hope they finally hit the right concept though, would love to see Hulk and Ric driving their pants of.
Being able to build a new design for all engine components, improved from lessons learned, could turn out really great (...or be a total dud). We will see when testing starts.
But realistically I'd see a season with a lot of hiccups again for Renault.
source: autosport.com
Posted: 22 Jan 2019, 19:28
by Ground Effect
Surprisingly, I hadn't seen below article until yesterday, don't know if it has been posted before, but it's allegedly quotes from Cyril and a response from Marko. I have to say, it's a great soap opera.
https://m.wheels24.co.za/FormulaOne/red ... l-20181221
Posted: 22 Jan 2019, 23:36
by godlameroso
Ground Effect wrote:
22 Jan 2019, 19:28
To me, this means that Renault's gains for 2019 are greater than any projected development from Honda's spec 3 engine. If Honda's improvement over spec 3 is linear based on previous data, Renault will be ahead of them at the start of 2019, except that gains aren't linear, and it may be that Honda improves more than Renault, and it can also be that Renault and Honda are more or less on even footing in 2019.
Posted: 28 Jan 2019, 16:15
by taperoo2k
godlameroso wrote:
22 Jan 2019, 23:36
22 Jan 2019, 19:28
It all boils down to which of the companies have got the PU design concept right and are able to extract performance from it, bringing them into contention with Mercedes and Ferrari over time. It would be great for F1 if Renault and Honda both crack the secret sauce for these PU's and can go onto challenge the front runners. I've got barely any interest in the war of words between Renault and Red Bull at this point, as it's a PR battle being waged based on tidbits of information that might not actually mean anything given how secretive F1 is. We'll know roughly where Renault and Honda are after the first few races.
Posted: 28 Jan 2019, 17:48
by godlameroso
As far as I can tell, I'd say peak power is similar, the big difference is engine endurance. That is how long can you run at higher power modes without burning all your fuel, how much can you get from the ERS, and how long will it hold together.
