Page 257 of 433
Posted: 23 Oct 2019, 15:12
by dans79
.poz wrote:
23 Oct 2019, 14:28
But you need a very capable ozone generator: at 12000 rpm with a turbo pressure of 3.5 bar a F1 engine use (1,6x 12000x3,5/4) 16.800l of air every minute or 280l of air per second
You need to adjust your math, as air is only ~20% oxygen at sea level, the other 80% is nitrogen, argon, and carbon dioxide etc.
Posted: 23 Oct 2019, 15:25
by Polite
.poz wrote:
23 Oct 2019, 14:28
BTW Antonini (former Ferrari PR) wrote that Ferrari advantage came form hybrid
https://www.formulapassion.it/motorspor ... 62846.html
"L’ho già detto ma repetita juvant, il vantaggio di potenza Ferrari non sarà facile da recuperare e/o metabolizzare per gli avversari. Ma fare polemiche striscianti non aiuta a colmare il divario e non è il modo più elegante di perdere."
"i told this before but repetita juvant (latin), the F. power advantage will not be easy to recover/digest for the others.
But making creeping controversy does not help to bridge the gap and is not the most elegant way of losing."
Amen :mrgreen:
Posted: 23 Oct 2019, 15:34
by .poz
dans79 wrote:
23 Oct 2019, 15:12
.poz wrote:
23 Oct 2019, 14:28
I wrote air, not oxygen :D
Anyway it's 56l of oxygen (O2) per second that can be replaced by 37,3l/s of ozone.
Posted: 23 Oct 2019, 15:37
by izzy
Polite wrote:
23 Oct 2019, 15:25
i'd say making it a controversy is generally a great way of bridging a gap in f1! How did the hydraulic accumulators that Red Bull and Mercedes were running in their suspensions get banned? That's right - Ferrari made a creeping controversy about it :D
FIA openly rely on teams to keep an eye on each other, after all. imo Ferrari have overdone it a bit and made the extra power too noticeable, so quite likely there'll be a clarification incoming for next year on the intercooler coolant front
Posted: 23 Oct 2019, 16:05
by .poz
Tommy Cookers wrote:
22 Oct 2019, 22:53
Dr. Acula wrote:
22 Oct 2019, 22:20
.... Because, sure you can get hydrogen out of oil, it's a hydrocarbon compound after all. But doing this changes the property of the oil severly over time. Because basically you turn it more and more into pure carbon.
hydrogen that's dissolved in oil isn't the hydrogen that's combined with carbon to be oil
so removing hydrogen that's dissolved in oil doesn't stop the oil being oil
Sorry, my fault, english is not my native language..
read as "if Ferrari have found a way to store big amount of hydrogen into oil..."
Posted: 23 Oct 2019, 16:33
by Polite
izzy wrote:
23 Oct 2019, 15:37
Polite wrote:
23 Oct 2019, 15:25
not really. Ferrari never told nothing to newspapers (and that was moveble aero).. and never gave tech relations to their partener teams to make them ask for controls by FIA. (Mercedes always uses ForceIndia for their protest =D> )
Posted: 23 Oct 2019, 16:52
by Tommy Cookers
Dr. Acula wrote:
22 Oct 2019, 23:47
22 Oct 2019, 22:53
Dr. Acula wrote:
22 Oct 2019, 22:20
Can you provide a number of how much hydrogen you can dissolve in a litre of oil at ambient pressure and temperature?
hydrogen has reverse solubility (in hydrocarbons eg 'oil')
ie its solubility increases with temperature (unlike eg the ready solubility of methane, ethane, butane, propane etc in 'oil')
try 'Phase Behavior of Hydrogen-light-Hydrocarbon Systems' by Benhom, Katz, & Williams
btw such solubility is important to enable hydrogenation processes (chemical reactions) for eg vehicle and human fuels
but yes if a bit of eg ozone or something can boost combustion efficiency or ITE by 2% that's 20 or 30 bhp
btw years ago I suggested dissolving hydrocarbon 'gases' in the fuel - cyclopentene ?, cyclopropene etc
this is of course now heavily restricted by the rules limiting fuel vapour pressure (and carbon atom count)
Posted: 23 Oct 2019, 17:23
by .poz
.poz wrote:
23 Oct 2019, 15:34
dans79 wrote:
23 Oct 2019, 15:12
.poz wrote:
23 Oct 2019, 14:28
AND THAT'S WRONG !
I divided by 4 (Four-stroke engine...) but actually you have intake in a single cylinder every 2 round of the crankshaft
so multiply everything by 2
Posted: 23 Oct 2019, 17:35
by LM10
izzy wrote:
23 Oct 2019, 15:37
Polite wrote:
23 Oct 2019, 15:25
Ferrari’s power advantage has already been there since the first half of last season. There have been several investigations and clarifications with numerous sensors, but eventually they still kept their power advantage.
You sound like you’re sure about Ferrari cheating when telling that they made it too noticeable. Well, if they have more power, they will simply use it. I don’t know why they should keep it secret, if everything is legal.
But you kind of made a good point. It would be dumb for a team to show all their potential, if it’s done illegal. Ferrari’s power advantage seems quite heavy. So probably they’re sure about the legality of the stuff they do. Think about it.
Posted: 23 Oct 2019, 18:00
by izzy
LM10 wrote:
23 Oct 2019, 17:35
lol well I love that logic :) i am just guessing of course, going on what i see and read, imo it's most likely a combination of something clever with the batteries and also something clever with the intercooler fluid. isn't it the case that only Ferrari use oil and everybody else uses water and glycol? cos generally oil has a lower specific heat than water, by a factor of 2 or something, so it wouldn't be your first choice as a coolant, if all you innocently wanted to do with it was cool something
with the electric side I'm thinking it's legal and next year we'll see some copies of it, maybe
Posted: 23 Oct 2019, 18:21
by LM10
izzy wrote:
23 Oct 2019, 18:00
LM10 wrote:
23 Oct 2019, 17:35
Not only I was sure about other teams copying whatever Ferrari has been doing, but almost 2 seasons gone and there still is no sign of similar PU behaviour from others. So, let's see what we're gonna witness next year.
Posted: 23 Oct 2019, 18:23
by LM10
MtthsMlw wrote:
22 Oct 2019, 21:59
LM10 wrote:
22 Oct 2019, 21:30
Doesn’t Ferrari reach top speed before Mercedes, but can’t keep it as long as them? Wouldn’t that be a sign of some kind of an MGU-related advantage?
@henry suggested that Ferrari might harvest with the K and H simultaneously at the very end of the straight, that's why they drop of their top speed before braking while others don't. This would put energy at like 200kw into the ES, the twin battery setup might come in handy there.
This was discussed in greater detail some pages ago.
Alright! Thank you.
Posted: 23 Oct 2019, 18:38
by hollus
Adding Ozone as an additive might help combustion (limited benefit in a fuel limited formula), but any improvement will be close to zero if the O3 is made from the incoming O2. It is the same atoms of oxygen you are adding in each case.
You might be only gaining about 15% enthalpy compared to the incoming oxygen (the bonds in ozone are weaker), and that only for the small amount of oxygen that you convert.
The overall reaction is
3O2→2O3ΔH=286kJ
Note that 3 O=O bonds of oxygen are broken, and 4 O-O bonds of ozone are formed. If the bond energy of ozone is E, then:
E=(3∗498+286)kJ/4mol=445kJ/mol
In any case, ozone is relatively toxic for humans (would be OK after combustion, but not in the every likely case that excess oxygen is used) and something like this would likely be banned on the spot.
Posted: 23 Oct 2019, 18:59
by izzy
LM10 wrote:
23 Oct 2019, 18:21
istr Charlie last year saying "we know what they're doing and it's legal", about the twin batteries, so it must be very, very clever. Fair play, afaic. There's an FIA dc sensor between the batteries and the rest of the car, so getting round it legally deserves mega respect. but it will get copied then, won't it? staff change teams, a few must know about and they can have a huge promotion
Posted: 23 Oct 2019, 19:08
by Tommy Cookers
dans79 wrote:
23 Oct 2019, 15:12
..... air is only ~20% oxygen at sea level, the other 80% is nitrogen, argon, and carbon dioxide etc.
after nitrogen and oxygen it's water vapour that's next - up to maybe 8% in Singapore
and afaik altitude doesn't affect the composition (except for the water vapour)
