Page 38 of 431
Re: Ferrari Power Unit
Posted: 20 Apr 2017, 16:44
by FW17
Looks like they have gone back to intercooler in the V of the engine or they are using a very tall straight VLIM rather than the curled types used by others
Posted: 20 Apr 2017, 16:47
by ferkan
Intercooler seems to be right above compressor.
http://en.f1i.com/magazine/magazine-tec ... ain.html/2
Posted: 20 Apr 2017, 17:04
by FW17
So a tall intercooler and a very small intake manifold something similar to the Porsche 919
Posted: 20 Apr 2017, 18:16
by dren
It's somewhat a return to their original 2015 PU. I really liked the layout of that even though it was a dog.
Posted: 20 Apr 2017, 19:39
by 63l8qrrfy6
dren wrote:
20 Apr 2017, 15:56
Mudflap wrote:
18 Apr 2017, 21:46
Lower LHS accessory kinda looks like a hydraulic pump ?
And the 2 lines going up into the vee can be hydraulic lines for the variable trumpet actuator ?
Or is it just a fuel pump ?
Are the fuel pumps electric or mechanically driven at these high pressures?
It has to be mechanically driven - I think it'd in the rules somewhere.
Posted: 20 Apr 2017, 19:49
by Juzh
dren wrote:
20 Apr 2017, 18:16
Ferrari 2015 PU was a dog? You mean 2014?
Posted: 20 Apr 2017, 20:03
by dren
Juzh wrote:
20 Apr 2017, 19:49
dren wrote:
20 Apr 2017, 18:16
Yes, you are correct. Time flies! :)
Posted: 21 Apr 2017, 16:30
by FW17
FW17 wrote:
21 Apr 2017, 16:02
21 Apr 2017, 15:56
FW17 wrote:
21 Apr 2017, 10:54
Don't think compressor size is limited by putting it in a cradle between gearbox and engine
Ferrari have the shortest routing for air with the inter cooler sitting in the V of the engine. They have done something totally different with the intake plenum. Something clever in the way they have made it, if the accommodated the Variable lengths with it, it will be one incredible design.
PS: Somehow the Honda engine thread has become the all engine discussion thread
The variable length runner are upside-down (inverted) in my opinion. They point downward into the V of the engine. The plenum is a big box with the intercooler at the back and the runnuers draw air from he bottom.
PZ lets move this to Ferrari Engine thread before it gets deleted
onventional variable intake manifolds are quite weighty and space-engaging. They are also likely to have the intake manifolds twisted or narrowed such that high-end power output is affected. Ferrari F12tdf avoids these problems by adopting a different kind of variable intake manifold. Its V12 engine utilizes 2 sets of trumpets (the black ones in picture below) which can move within the intake plenums, varying the effective length of intake manifolds. The trumpets are moved by hydraulic actuators located between the two plenums. In the F12tdf, the trumpets vary between long and short positions, but theoretically this design can be easily modified to vary continuously between the two positions.
One shortcoming of this design is limited range of adjustment. As the movable trumpets are quite short, the difference beween long and short modes are not as big as conventional VIM systems. However, this problem could be solved by using multiple trumpet sections working in telescopic style.
Posted: 30 Apr 2017, 07:18
by FW17
Ferrari factory team is on the 3rd turbo charger and it is only the 4th race of the season. The team calls it strategic
Are they using different turbo sizing for different track characteristics ?
Posted: 30 Apr 2017, 08:31
by ripper
As far as I have understand they found a reliability issue in TC first spec (the one that blew in kimi's car) and the newly fitted one should address that. I've read that the old spec had problems with high temperature, hence the problem in Bahrain.
I didn't read anything about sizing, performance and so on.
Posted: 30 Apr 2017, 13:33
by PlatinumZealot
Ferrari have negated the magic q3 button effect. Whether they have one of their own or they achieved the removal of Mercedes' no more sudden power increse in Q3 for Merc from now on.
Posted: 30 Apr 2017, 19:49
by ripper
I don't think so. In first sector mercs were better than Ferrari and the silver arrows can use the same strat on race start or safety car.
In my opinion what Mercedes gained in s1 was clawed back in s2 and s3 due to better df/traction/tyre management/whatever. I wish that merc and fer pu had the same q3 mode, but I think that the German pu is ahead
Posted: 30 Apr 2017, 20:29
by F1NAC
30 Apr 2017, 13:33
they still have the edge on straights. in S2, S3 Ferrari aced (bar backstraight) https://twitter.com/FiftyBuckss/status/ ... 8715917313
Posted: 30 Apr 2017, 21:42
by Juzh
30 Apr 2017, 13:33
Nice optimism. Back to reality now:
https://streamable.com/jah99
Posted: 30 Apr 2017, 22:09
by Frafer
Juzh wrote:
30 Apr 2017, 21:42
30 Apr 2017, 13:33
i guess that ferraris've used a slightly more draggy setup in order to shine in the corners
