Page 1 of 1
F1 cockpit head surround contruction
Posted: 29 Jan 2015, 15:31
by f1showcars
Hi I was just wondering how these was actually made. I know they have foam inside but are they then covered with Kevlar or carbon fiber?
Re: F1 cockpit head surround contruction
Posted: 29 Jan 2015, 22:22
by Marco Duchhardt
Hello,
i think its from Carbon fibre because, i have a memorabilia of the Head Sourround. :D
Posted: 29 Jan 2015, 22:38
by krisfx
It's fairly thin carbon fibre with a foam innner.
The two compounds of foam are pink for temps lower than 30 and blue for anything above.
It hardens under impact, I'm sure Scarbs has an article on it :)
Posted: 30 Jan 2015, 15:08
by scottracing
its two plies of carbon / kevlar twill then filled with foam after curing, quite a complex part to make
Posted: 30 Jan 2015, 15:57
by Ciro Pabón
Well, it's a relatively simple question to answer, perfect for my limited knowledge, specially because the regulations are clear:
- Confor foam
This is a trademarked foam, quite particular, as most materials, according to manufacturer EAR "would amplify the rebound significantly after head impact, or they would bottom out, or collapse completely, offering little physical protection".
This foam hardens when impacted, as krisfx mentions. It also rebounds little.
This is the article by Scarbs that krisfx talks about:
http://scarbsf1.com/blog1/2013/01/16/in ... ead-rests/
There are three differente grades of foam (instead of the two krisfx mentions) depending on ambient temperature, at least according to FIA.
- "Soft" carbon fibre cover
The foam is covered with carbon fiber for aerodynamic purposes. As you can imagine, regular hard carbon fiber would negate the impact adsorbing effects of the Confor foam. Hence you have to use a thin cover made of carbon fiber that is soft and almost, according to Scarbs, "rubber like".
You can read Scarbs article to find the curious ways in which teams go around the rules for less aerodynamic drag.
There is also a nice rather old booklet I read by Sid Walkins, called Walking Away (with one of the most spectacular pictures of an accident I've ever seen in a booklet about safety, if you ask me).
FIA's idea seems to be for everything to be reduced to pieces, except the driver (and perhaps the tyres)
I mention this booklet because it explains the curious ways in which this technology has moved into rally racing seats.
Same headrest idea, but only made of foam: if you're going to learn how to do headrests, start with these
Posted: 30 Jan 2015, 16:27
by f1showcars
Hi
Thanks for the replys I have read the scarbs page.
The only question really is if the carbon covering the confur foam is flexible wouldnt the carbon fiber be in raw form as otherwise it wouldnt be flexible?
Posted: 30 Jan 2015, 16:51
by f1showcars
http://www.paddockmotorsport.co.uk/wp-c ... G_0226.jpg
Had a quick look around on the net see the link for how force india head rest looks like . I presume they could then just squash the foam through the gaps? I have some ex marussia confor foam cockpit surrounds so im presume they do it that way and not injecting it inside.Although this could be different team to team
